Negative battery cable/strap
Old 10-25-2014, 01:38 PM
raleighBahn
raleighBahn's Avatar
Default Negative battery cable/strap
Hey folks,
My ground strap from negative battery post to block ground has significant corossion and I'd like to replace. Any source for these today beyond oem or making my own?
Old 10-25-2014, 02:02 PM
V2Rocket
Rainman
V2Rocket's Avatar
There is a suitable option on the shelf at your local Oreilly/Autozone.
I think the 9" cable is sufficiently long. About $8?
Old 10-25-2014, 04:09 PM
raleighBahn
It's a forked cable, with one end short going to firewall, the other to back of engine block. Will go look - doubtful I'll find that, but worth a try. Don't need it imminently as I'm pulling out turbo to replace AOS seals.
Old 10-25-2014, 07:32 PM
michael7810
michael7810's Avatar
There's always the Ice Shark kit. comes with both battery cables plus alternator and fuse box wires. Have not installed mine yet but the quality is outstanding. I think it was $275 shipped.
Old 10-25-2014, 07:48 PM
raleighBahn
Are these still for sale, and if so, have a link? Thanks!
EDIT: just found site... thanks!
Old 10-25-2014, 09:53 PM
V2Rocket
Rainman
V2Rocket's Avatar
Your cable must be different than I imagine- my car came with the braided copper from the block to the firewall, and a separate cable from another spot on the firewall to the battery.
Old 10-25-2014, 10:27 PM
MAGK944
MAGK944's Avatar
You can always un-fork them, ie: fit two cables instead of one forked one. imo tinned copper is a good option to replace the one to the block. It gets hot back there and the stock insulated cable tends to lose the installation over time anyway.
Old 10-26-2014, 12:19 AM
raleighBahn
Yes - it was in bad shape - cracking and corroded.
Old 10-27-2014, 11:17 AM
User 52121
User 52121's Avatar
I bought a kit off of Robby here - I believe it's pretty much an exact replica of the IceShark kit.
Nice, quality stuff, all perfect length and ready to bolt on. The wiring that came out of my car was pretty nasty.
Old 10-27-2014, 12:59 PM
951kaos
951kaos's Avatar
Here is the link that Robby posted for Ice Shark cables. I bought and installed a set and they are very well made and have well laid out installation guide. If he does not respond to you right away; he may be busy and will get back to you as soon as he can.
https://rennlist.com/forums/924-931-...able-kits.html
Quick Reply: Negative battery cable/strap
