Help me build a 3L+
#31
I'm aiming for around stock 951 performance maybe with more low end torque and revs near to stock. I'm open to suggestions...or criticisms in the direction of the build I am planning.
#32
I've wondered what a 8v head on a NA 3.0 block would do but without a big cam and revving it fairly high I'd be a little surprised if it did 250 bhp with good low end torque, even with fancy management. Isn't this 85 bhp more than a 2.7 ?
#33
Here's a little help. If you decide to offset grind the crank and use DSM rods this a good deal. The Manley H beam rods are nearly identical to Eagle rods.
http://www.dsmtuners.com/threads/bni...-beams.486681/
#34
I don't see a problem getting to stock turbo power levels (220hp) with a stock cam, flowed head, 48mm intake valves and MAP (TechGT) engine management with DFU's and sequential...but I might be wrong...let's say it's a target I'm aiming for.
#35
I understand the 3.0/2.5 block differences, those are not a concern to me. There are proven 3.0's builds from 2.5 blocks and I would rather mess with what I have than go looking for a "true" 3.0 block with a negligible benefits for my NA build. Plus I''ll be sleeving it anyway.
#37
Ah yes 2.7, forgot about that one, rarer then rocking horse s#it and twice the price. A flowed 2.5 head with larger intake valves will more than serve my purpose.
