Blown 944 Hybrid Stroker DIY Guide
#211
Rainman
I like that Honda process - have seen it a few times too.
Wouldn't worry too much about lower cylinder temps but if you wanted, it'd be a good time to add piston squirters and a BF-oil cooler.
Subaru guys "pin" their open-deck blocks to secure the cylinder bores to the outer case walls...seems to work OK for them.
#212
Quit Smokin'
I wanted the filler to adhere to the walls of the water jacket as much as possible.
#214
Barry Hart of Hartech has stated that several S2 engines he's stripped have shown evidence of piston pickup at the bottom of the cylinders. With the tight clearances perhaps that's one of the reasons Porsche fitted squirters to the 968 block.
#215
Basically, heat is the enemy. When a piston gets hot it expands, so you need room between the piston and cylinder wall so the piston runs smoothly in the cylinder. Over expansion will cause galling.
There's a few ways to deal with the extra heat; use greater PTW clearance so the piston remains smaller than the cylinder at hot temps. Oil squirters help keep the piston cooler. On my engine I added ceramic heat barrier coating to the piston top and low friction skirt coating to reduce piston temperature.
#216
Hard block question
I have my engine apart and the bare block is back from hot tanking. I want to clean up the water passages some more and add the Moroso block filler but want to confirm what to block off from the block filler in the front water passages for a street engine. My understanding is fill the lower hole but leave the center one open. Should I use some rubber hose in the front while the hard block is setting up and remove it once it is formed up or just some paper towels like Shawn did?
#217
#218
I have had this same question from start of the posting of offsets grinds builds.
If I understand correctly after the endless researching:
1.89" is the actual rod measurement if you were to measure the bore of the rod
1.771" is the size of the rod journal if you measure the crank.
The difference being the bearing placement.
#221
You can get aluminum 156mm rods from FFWD Connection and a 1.18" comp height piston from the JE/SRP catalog and build a long rod stroker 2.8 that will handle as much rpm as the oil pump will allow.
#222
The difference being the thickness of the bearing.
#223
2.8L (100x88.0) with 156mm rods gives a rod ratio of 1.77.
This suggests to me that a stock-ish 2.7 should be a happier 16V engine running higher revs than the usual 2.8 stroker spec.
Destroking a 2.5L crank from 78.9mm to 71.9mm with 156mm rods would give a rod ratio of 2.17, which would be even "better" for high rpm use.
With a 104mm bore the engine would "still" make 2443cc which is arguably not "too" small for a high rpm engine. Add a dry sump with all other supporting mods and how about revving it to 9k+?
(With a 100mm bore the engine would make 2258cc, and by then we would probably want to use a classic 2.3L 5 cyl Audi engine instead).
#224
Rainman
Thom,
Rod ratio is nice but it's not everything - the old rule of "run the longest rod you can fit" still applies.
For example, the Ferrari 458 (9000rpm 4.5 V8) has an 81mm stroke and a rod of 144mm...a ratio of 1.77.
#225
The Ferrari 458 makes a peak torque of 67.5 N.m per cylinder.
I would expect a good 3L 16V 951 engine to make about 175 N.m per cylinder, which is more than 2.5 times as much.
While lateral cylinder load may not be 2.5 times as much, I think we can see where the rod ratio can have some importance on longevity when "too high" the stroke gets.
I know this is some kind of "how long is a piece of string" topic but with no real world feedback that makes many whatnots. I wish Duke did a 24Hr full speed endurance test at Nardo!
