I may have pulled a stupid...
Old 01-13-2014, 07:55 PM
Kwenak
Kwenak's Avatar
Default I may have pulled a stupid...
Hey all. I'm working on a rebuild. I have everything pulled apart. Sent the block out to get bored, got new pistons. Everything is moving nicely. However, when I pulled the crank out I didn't take the flywheel off first. And now I want to send the crank out for some work. Is there a trick to get the flywheel off when the crank is out? Or should I just put the crank back in, secure it and remove it that way?
Thanks for any advice.
Old 01-13-2014, 08:30 PM
Dougs951
Dougs951's Avatar
Nope it should come off easy enough.
Old 01-13-2014, 08:50 PM
Fluidplay
Fluidplay's Avatar
Impact wrench...should be able to pull it right off.
Old 01-13-2014, 09:34 PM
theedge
theedge's Avatar
Or just wrap it in a blanket, clamp it in a vise and go at it the usual way.
Old 01-13-2014, 10:36 PM
Tom M'Guinn
Tom M'Guinn's Avatar
Agree with others. Impact wrench is easiest. In fact, putting back in the block doesn't help much because the flywheel lock needs the bell housing to work, and the bell housing covers the flywheel.
Old 01-14-2014, 12:44 AM
theedge
theedge's Avatar
Two pressure plate bolts threaded back in and a length of pipe braced against engine stand/table/whatever works for that.
Sweet, post 14k.
Old 01-14-2014, 12:56 AM
Tom M'Guinn
Sweet, post 14k.
Good call on both points!
Old 01-14-2014, 12:58 AM
Dougs951S
Dougs951S's Avatar
Sweet, post 14k.
I've done this lots of times and have yet to break a bolt. PP bolts are usually pretty high grade and are unlikely to sheer.
Quick Reply: I may have pulled a stupid...
