can you connect wideband o2 sensor to dme?
Old 12-26-2013, 10:52 AM
Carlsbergas
Carlsbergas's Avatar
So i saw a post somewhere on rennlist that you can connect wideband o2 sensor to the dme. If thats possible i would be able to replace my old o2 and have wideband. If not ill have to weld a new o2 bunk
Here is the post: I have also heard the 5 wire wide/narrow sensor from a late model VW could be used. It has wideband capability for future tuning, and they are a whopping $38 from 1stvwparts.
LSU sensor info:
http://wbo2.com/lsu/default.htm
The Gray and white wires on the VW sensor are for the heater and the black wire is the narrowband signal.
But i have aem wideband tho
Old 12-26-2013, 11:15 AM
lee101315
lee101315's Avatar
No, A wide band O2 reads 0-5V, and a narrow band reads 0-1V.
Old 12-26-2013, 11:19 AM
Carlsbergas
Guesz ill have to make another hole in the exhaust for wideband o2
Old 12-26-2013, 11:23 AM
User 52121
User 52121's Avatar
That is correct.
You will need the proper bung welded in, in the proper location. Lindsey's site has a good pic of it: http://www.lindseyracing.com/LR/Parts/WBO2LOCATION.html
Lindsey also sells the bung: http://www.lindseyracing.com/LR/Porsche//IM-3736.html
Old 12-26-2013, 11:33 AM
Carlsbergas
Originally Posted by OmniGLH
That is correct.
Just found out that o2 bung was already in the kit!
Thanks! Great info i might even get it done today
Old 12-26-2013, 01:21 PM
Tom M'Guinn
Tom M'Guinn's Avatar
The factory oxygen sensor location gets too hot for a typical wideband sensor, so you want to put the wideband sensor down by the starter, and with the wires pointing up slightly.
Old 12-26-2013, 02:14 PM
theedge
theedge's Avatar
Many wideband controllers have a narrowband output, a 0-1 volt output, that can be used in place of narrowband sensors.
Old 12-26-2013, 04:07 PM
lee101315
lee101315's Avatar
This is a good read on wideband vs narrowband O2 sensors
http://www.infinitegarage.com/?p=287
Old 12-26-2013, 04:08 PM
lee101315
lee101315's Avatar
Yes, wideband 02 sensors also calculate oxygen content with a sophisticated temperature sensor...so the crossover pipe is a no-no for a wideband.
Old 12-26-2013, 06:05 PM
Carlsbergas
Just ordered bosch 15735 3wire o2 sensor, figured i should change the narrowband too. God knows how long its been there, and my mpg is ****ty im runing rich too, cause under wot my car shoots some spectacular afterfires and my narrowband gauge says im runing rich under wot
Then ill be focusing on pre turbo exhaust leaks.. i got couple of them
Old 12-26-2013, 09:36 PM
lee101315
lee101315's Avatar
Just ordered bosch 15735 3wire o2 sensor, figured i should change the narrowband too. God knows how long its been there, and my mpg is ****ty im runing rich too, cause under wot my car shoots some spectacular afterfires and my narrowband gauge says im runing rich under wot Then ill be focusing on pre turbo exhaust leaks.. i got couple of them
O2 sensors are supposed to be changed every 60-80k, maintenance that's commonly overlooked. In the older cars, the oxygen sensor is bypassed @ WOT, so if you're running rich, it's something else. A new sensor will definitely improve your idle and part throttle driving.
Old 12-26-2013, 09:41 PM
Carlsbergas
About part throttle driving. Having throttle at ~80-90% car feels like it pulls more than at 100% but maybe its just me. Im still going to do TB calibration and idle adjustment
Old 12-26-2013, 10:03 PM
User 52121
User 52121's Avatar
Boost leak.
Old 12-26-2013, 10:16 PM
Carlsbergas
I swear to god. I have no more ideas where i could have a boost leak.. im giving up
Quick Reply: can you connect wideband o2 sensor to dme?
