Oil Pressure Sender recomendations
Are you talking factory replacement or a separate gauge?
Give the cheap URO one a try. It's 1/4 the price of the VDO. Mine's going strong for about a year now, and it's a fairly easy job to replace it so you don't have that much to lose.
Lol you still didn't answer my question!!!
Are you looking for a SENDING UNIT that sends to the factory cluster, or a STAND ALONE SENDER AND GAUGE (or gauge that uses the factory sender)??
Lol. Uro is cheap and works. Easy to swap.
WRONGLY ACCUSED!
I kept my stock pressure sensor by using the Lindsey Racing oil pressure adapter.
http://www.lindseyracing.com/LR/Parts/944OILADAPT.html
I installed a SPA dual oil pressure oil temperature gauge.
http://www.lindseyracing.com/LR/Parts/944OILDP.html
Uro will last 1-3 years...
Factory will last 10-15 years...
I found it wasn't that super easy to replace because it is a tight fit and the wrench only turns like 2 degrees. It's simple for sure but it takes enough time that I decided to spend the 80$ vs 20$ and be done with it for a decade...
That is my 2¢.
That is my 2¢.
