CyCloNe!'s Build Thread
Hey guys I've been here for a few years and I realized I don't have a build thread, so I figured why not start one. Here's a few pics of the car currently as well as a few other shots.
List of Current Maintenance:
944 Turbo Maintenance:
Clutch 8/01/09
Cap and Rotor 8/17/09
Ignition Coil 8/17/09
Spark Plugs 8/19/09
Tires 2/15/10
Vac Lines and Venturi Delete 5/13/10
Fuel Pump 7/25/10
Rear Shocks 8/11/10
Idle Air Valve 8/20/10
Rear Right Wheel Bearing 9/05/10
Oxygen Sensor 09/05/10
Fuel Pressue Regulator 5/25/11
Mass Air Sensor 5/25/11
Map Sensor 5/25/11
Fuel Damper Hose 7/20/11
Timing Belt/Balance Belt/Water pump 10/21/11
Serpentine Belt 10/21/11
Wires 1/15/12
Front Strut Assemblies 5/15/12
Fuel Injectors 4/10/12
Front Wheel Bearings and Seals 4/13/12
Throttle Switch 4/13/12
Intercooler Coupler Kit 5/17/12
Steel Arm Converison 10/01/12
Ball Joints 10/01/12
Control Arm Bushings and Castor Blocks 10/01/12
New Tires 1/05/13
AOS Seals 2/08/13
Clutch 8/01/09
Spark Plugs 8/19/09
Tires 2/15/10
Fuel Pump 7/25/10
Rear Shocks 8/11/10
Map Sensor 5/25/11
Wires 1/15/12
New Tires 1/05/13
AOS Seals 2/08/13
Spring/Summer Projects:
Install Polished Shaved Cam Housing
NA Late Cam
Head and Head-gasket Job
Front Seals
Rear Driver Wheel Bearing
Crank/Reference Sensors
Temp Sender for Gauge
Radiator Hose kit (All Coolant Lines)
Upgrade T04E to GT3076R wheel and housing or K27/6 turbo instead (still deciding)
Hopefully some interior pieces or carpet getting replaced. (Shift boot, Door Cards, Carpet, and Quarter Cards)
NA Late Cam
Front Seals
Seats are universal vinyl ones off ebay paid $250 for them, mine were trashed so I just wanted to make the interior less torn apart. I plan to get some cheap factory ones and an upholstery kit in black. Also yes my interior was burgundy, I took some VHT vinyl paint and went to town, that's how she looks after 1.5 years later. Sadly after I painted them I found a permanent dye by VHT on summit-racing but it's held up pretty well. I'm going to replace with factory black parts especially the door and rear cards.
Also here's my Xschop Strut setup, 300lb Springs, Early Strut Housings Modified for Late Models, with KYB Inserts. I plan to change the inserts to something more stiff and get some shorter springs, these are 10" I believe and want to go with 8" so I have more adjustment. Right now I have the car as low as it will go with these springs which is like .5" lower than stock.
I'll look forward to this thread, thats a really nice turbo. In the engine pic, is that an Optima battery sitting on it's side ?? Never saw one that fit but can you actually even mount those upside down and they still work?
