Rogue Tuning: DME Logger!
#32
There are a few descent tablets out there that can use the burg bootloader to boot os like windows, ubuntu and android and usb jack. Will probably grind up a custom mount to the 951 dash and see if the software guage view can fit in a 9" tablet screen. Might just remove the radio and lower panel and move guages to a side pod. I'm sure someone has replaced the radio for in dash tablet somewhere out there.
#33
I cannot give enough praise to Joshua, not just for his high-tech additions to the limited 944 market, but most impressively his exemplary customer service skills. It is amazing that his products have helped not only bring our aging cars into the 21st century, but have kept many of them running period. I am at a loss of words to explain how pleased I am with my A-Tune. I am now running E85 with 55lb inj and a 3bar fpr. I basically received tuning advice and product support on demand with Joshua of Rogue Tuning.
The fact that I can receive almost instant response from Joshua, is almost as amazing as the fact that I can even private message Joshua, a Rennlist Business Partner, here on this forum. Rogue Tuning's customer service and response more than justify the price you pay for Joshua's products.
#34
Nice! I really need this to sort out my jumpy gauges and high temp issues.
When will the tuning application be ready aprox? Would be good to order at the same time.
Too bad the 951 is tucked away for the winter!
/Peter
/Peter
#35
Josh: Will the DME accept either an analog or digital WB O2 input? I too have an Innovate LC-1 and believe the data output is analog 1-5v and that it is transmitted through the serial out port. Pls confirm this and the wiring. Thanks, Mike
#36
Small Business Partner
Thanks for the compliments!
Peter, I'm current working on getting the Tuning side done, and shouldn't be much longer...
The DME needs a 0-5volt analog signal. Your LC-1 has the correct output, and should work well (I also use the LC-1 in both my turbo & NA).
#38
Refresh rate is 15-20hz.
ALDL is an (old) proprietary GM datastream (and really slow). I have written my own serial-datastream, not emulator-tracing. But the concept is pretty much the same as the ALDL stuff: the DME sends out packets of data, which your laptop receives and then converts the raw data into something meaningful.
Yes, it is all in Tunerpro - it is really the most flexible tuning application and works quite well.
#42
Great stuff, Josh. I have a few questions...
What's the timebase for the data when you export it? It would be great if it was UTC so you could align the data in time with data collected by other systems, e.g. to do a video overlay. I'm assuming the DME isn't keeping a real time clock. Is there an appreciable time delay between data acquisition and delivery to the computer? Does the protocol have a way to measure/compensate for that?
Also, is the protocol to the computer a trade secret? Can I make my own real-time display with a Raspberry Pi and an LCD screen?
Again, great stuff. I'm glad to see people innovating in this space.
#43
Only tough part is having the laptop running while on the track. I don't think it would survive! Wondering if perhaps it's worth ditching my crusty old laptop (that I keep in the garage and also run TunerPro on) for one of those new Windows Surface tablets. Then just build a foam holder and stuff it somewhere in the car where it's secure.
#44
Speaking of laptops, I have a tiny Lenovo with 10" screen and an SSD. The battery life is good for a few hours and it fits in the glovebox, and the glovebox door shuts. It will log indefinitely with a car power adapter. I also plan to do a video out from my laptop to my 7" slideout Eclipse (avn7000) headunit for an auxiliary input. Logging works great with the little laptop and you should be able to pick one up for less than $150. Its a Lenovo Ideapad S10 and is at least 3 years old now.
#45
There are a bunch for ~$150 on eBay.
