Rogue Tuning: DME Logger!
Old 10-23-2012, 02:18 PM
White_951
White_951's Avatar
Is this software different from the TunerPro software I already purchased????
Old 10-23-2012, 02:29 PM
74goldtarga
74goldtarga's Avatar
You should still have a wideband. This is different than tuner pro (which I believe Josh offers for free on his website).
Josh, put me high on the list - will order as soon as I can. I have 6 gallons of E85 in the garage waiting to be used.
Old 10-23-2012, 06:11 PM
gregeast
gregeast's Avatar
Congrats Joshua, looking forward to it!
Old 10-23-2012, 06:38 PM
refresh951
refresh951's Avatar
Nice work Joshua! As soon as the order link goes live I am in. Having access to every sensor is going to be so helpful for troubleshooting and optimization. Thanks for making it so affordable.
Old 10-23-2012, 08:31 PM
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
Originally Posted by 86 951 Driver
Would this take the place of say Wideband O2 and boost gauge? How does it hook up to the car's computer?
Originally Posted by blown 944
Josh is probably busy do I'll answer the best I can.
You will still need a wide bandn and to tap a signal from. I'm not sure which ones he's set up for. I have Zietronix and he has innovate.
It is spliced into a couple of wires on the harness and there is a little box that converts to USB. Super easy to install.
Thanks Sid. And Sid is correct, that in order for the DME to log true AFR, you will need a WBO2 (I personally use the LC-1 from Innovate), and hook up the 0-5volt output from the WBO2 controller to the DME.
Old 10-23-2012, 08:35 PM
Scott H
Scott H's Avatar
$35 less than the Innovate 5 channel logger, smaller, and logs more stuff. Yup that's a surefire winner in my book.
Old 10-23-2012, 08:38 PM
Rogue_Ant
Rogue_Ant's Avatar
Originally Posted by Zeff
bam I'm down for one as soon as the paypal goes online.
edit - I guess I jumped the gun on the post... this device is just for logging, correct? The first thread mentioned tuning as well, is that a separate thing entirely that you're working on or will the logger allow saved changes with the TunerPro software to the mtune setup.
Originally Posted by dillon410021
my question as well
Looking over Josh's site, you can opt for the Ostrich setup and do you tuning that way, but I was under the impression that he was working on a plug and play without the chip emulator. Hopefully Joshua can clarify this later today.
Sorry for any confusion! Yes, this announcement is the just the logger. The direct-tuning is on the way, but I'm not quite finished with it. The tuning is a separate unit. The two units work in concert - one logs, and the other tunes! One does not take the place of the other.
Old 10-23-2012, 08:41 PM
Rogue_Ant
Rogue_Ant's Avatar
TunerPro is the software application which allows us to setup how we want. Think of it as the box, and then we can put what we want into the box.
Yes, I still offer the free-DIY tuning. But that is limited to factory-style software, and does not work with my Tunes.
The logger and direct access tuner also uses the TunerPro software, but we have different files & hardware to make it work with my Tunes.
Old 10-23-2012, 08:43 PM
Rogue_Ant
Rogue_Ant's Avatar
Thanks! Yeah, I have the Innovate 5 channel logger, and it just sits in my closet. The serial-2-USB conversion is temperamental, and to log 5 channels, I had to hook up over 10 wires! No, I much prefer my logger, 2-wire hookup, and native USB.
Old 10-23-2012, 09:20 PM
toddk911
Drive-by provocation guy
toddk911's Avatar
Right on. Everyone's going to love this. It's been very instrumental for me. It's about time
Just the time saved in diagnostics has been well worth it.
Now I just need a small pc that I can power off of 12v and I'll use it as a set of gauges.
Again awesome work!!!
DC to AC inverter.
Old 10-23-2012, 10:39 PM
jb-kix
jb-kix's Avatar
YES!
Old 10-23-2012, 10:47 PM
numbskull
numbskull's Avatar
Nice work! That is going to save a lot of tuning time. What OS does the software install to? man it would be great to have an android tablet mounted to the dash to display everything. I can then ditch my hong kong made digital panel that displays maf voltage to make room for sunglasses again! No more room under radio. Great job!
Old 10-23-2012, 11:03 PM
Rogue_Ant
Rogue_Ant's Avatar
The OS needed is Windows XP or newer.
An Android application would be cool... but I have way too many things to get done before even thinking about that!
Old 10-23-2012, 11:47 PM
zerMATT951
zerMATT951's Avatar
Great news Joshua!
Old 10-24-2012, 12:01 AM
techartisan
techartisan's Avatar
Now I just need a small pc that I can power off of 12v and I'll use it as a set of gauges.!
Originally Posted by toddk911
DC to AC inverter.
thats a waste. DC to AC by inverter then AC to DC by the PSU?
DC to DC PSU makes more sense.
Grab any Mini-ITX motherboard, Maybe spring for an automotive enclosure (looks almost like an amp) and youre set.
Quick Reply: Rogue Tuning: DME Logger!
