AOS/intake hose to get rid of 'squid'?
Does Lindsey (or anyone) sell a hose to bypass the 'squid' tube and the two shorter hoses? I'm running an mbc and would just like to leave the metal 'squid' tubes off (along with leaving off the CV and CV mount). I'm going to be ordering some stuff from Lindsey anyway and have looked around for this but didn't see anything. Or is it included in the idle stabilizer/venturi delete with vacuum hose kit?
Yep, LR makes a long AOS hose that goes straight to the intake. http://www.lindseyracing.com/LR/Pors...OS-102-XL.html
I highly recommend their Venturi delete kit, Cleans up everything real nice and with a MBC, you can remove the cycling valve, all it's hard lines, and run a cleaner vaccum system
Lindsey had the check valve in stock when I ordered my AOS long hose a couple of days ago...I've seen you can make something else, but since I got their venturi delete, blue silicone radiator hoses and vacuum lines, it just made sense to keep it all the same!
