Thinking about a large oil cooler. good or bad idea?
Old 10-08-2012, 09:12 PM
Paulyy
Professional Hoon
Paulyy's Avatar
Default Thinking about a large oil cooler. good or bad idea?
I was thinking though the idea of a larger oil cooler..
I was looking at the eBay coolers and did a search on the rx7 forums and they say the cheap coolers do the same job as the expensive ones..
So what if i mount this one behind my intercooler?
bad idea as air needs to pass through the intercooler?
Old 10-08-2012, 09:35 PM
spoolin51
spoolin51's Avatar
Then why do they make expensive ones? Regardless, if you are looking for efficiency then buy a quality cooler (mocal etc) you get what you pay for when it comes to this stuff. You can run a oil cooler behind your intercooler that shouldn't be an issue. Depends on what your goals are..
Old 10-08-2012, 09:44 PM
333pg333
333pg333's Avatar
Mount it somewhere else. Not behind i/c or rad.
Old 10-08-2012, 09:52 PM
dmcampbell
dmcampbell's Avatar
I am pleased with the KISS aux cooler that mounts on the drivers side and comes with the lines to easily plumb in. This cooler lowered my oil temps at Sebring in dead summer to an acceptable 240 - 245 degrees. I bought mine from Lindsey. Mike
Old 10-08-2012, 09:56 PM
Paulyy
Professional Hoon
Paulyy's Avatar
the only difference i can see with the more expensive ones are the end tanks are different and the cooling fins may be different.
end tanks are easy to modify with the right equipment which i've got.
basically my goals are for a reliable 400 rwhp street motor that does see boost often and WOT now and then and possibly a few track days.
I was thinking if i go behind the IC (only place i can think of) i'll make ducting from the old oil cooler original position to flow to the new one on either side?
Old 10-08-2012, 09:59 PM
thingo
thingo's Avatar
The 993 oil cooler works well.
Old 10-08-2012, 10:29 PM
refresh951
refresh951's Avatar
I like what Rick Cannell did. Mocal 13 row addition. I bought the same for $90 on Ebay:
Old 10-08-2012, 11:34 PM
xsboost90
xsboost90's Avatar
i bought a nice cooler on ebay, an10 fittings and looks like the one above. Works great. DO not use the rx7 cooler, it was too big and didnt work properly on two cars that we put them on. Ebay cooler was a big upgrade believe it or not. Similar to the Satrab but not as nicely built.
Old 10-09-2012, 01:10 AM
Paulyy
Professional Hoon
Paulyy's Avatar
did the RX7 coolers have the in and out on the same tank with out a divider? that's what it looks like to me.
Old 10-09-2012, 02:59 AM
333pg333
333pg333's Avatar
Ironic or not that you mention Rick Cannell looking at your car Shawn??
333pg333
333pg333's Avatar
+1 and you can put it where the stock one goes.
Old 10-09-2012, 03:59 AM
Paulyy
Professional Hoon
Paulyy's Avatar
I'll have to give that a sus. cheers!
Old 10-09-2012, 10:19 AM
lee101315
lee101315's Avatar
Have you considered one from a 968? Its almost double the size of the 951, and will bolt in the same place. But you'll also have to change the oil filter housing as well...
Old 10-09-2012, 11:38 AM
chrenan
chrenan's Avatar
Any more info on this guys? I bought an RX7 oil cooler setup off JoshB, he said his worked well.
Old 10-09-2012, 01:15 PM
Oddjob
Oddjob's Avatar
Ive played around w/ several oil cooler configurations on track cars.
I have now opted away from putting anything in front of the radiator, and would think in front of or behind the intercooler would also be a less than desirable mounting location.
Currently running two mocal coolers in-series installed on either side of the radiator, -13 on the driver side and a -19 on the passenger side (this requires removal of the PS cooling coil and the windshield washer reservoir and if retaining the brake cooling ducts, some minor sheet metal trimming).
One lingering question that I had/have that I would like to hear some thoughts on:
Line size, -10 large enough or will it be restrictive and cause too much pressure drop, or is -12 better for lower pressure drop. Without measuring pressure before and after, there is no way of knowing what the pressure drop would be. What have you guys been using?
Quick Reply: Thinking about a large oil cooler. good or bad idea?
