TonyG > New Race Car Build Thread
Old 03-24-2017, 12:09 AM
  #1426
thingo
thingo's Avatar
I think it's the twist in the driveshaft that caused a lot of problems, we have too much latency that can't be compensated for.
Old 03-24-2017, 12:10 AM
  #1427
thingo
thingo's Avatar
Old 03-24-2017, 12:43 AM
  #1428
TonyG
Rennlist Junkie Forever
TonyG's Avatar
Did you discuss the issue with Motec?
I would think I could use the crank sensor and add a sensor at the trans input to calculate the diff...
TonyG
Old 03-24-2017, 01:44 AM
  #1429
333pg333
333pg333's Avatar
TonyG
Pun intended? I would think that range would vary too much to run a calc between the two, no?
Old 03-24-2017, 02:15 AM
  #1430
TonyG
TonyG's Avatar
I was just throwing it out there.
I have no idea since I've not set mine up either.
That's why I was asking.
We need to make Rod talk more... :-)
TonyG
Old 03-24-2017, 02:42 AM
  #1431
333pg333
333pg333's Avatar
He's inscrutable...
Old 03-24-2017, 03:09 AM
  #1432
TonyG
TonyG's Avatar
He's inscrutable...
Oh I get it...
We just need him to give up his hard earned data....
TonyG
Old 03-24-2017, 04:10 AM
  #1433
thingo
thingo's Avatar
TonyG
We had one of the guys from motec at the track with us for a whole weekend, there may be a workaround, we have yet to find it, you can't mindread the drivers foot. We decided we need a better driveshaft for the best solution, I'm working on that...
Old 03-24-2017, 07:16 AM
  #1434
333pg333
333pg333's Avatar
You guys have left me behind in the dust. You're on your own from here on in. :-)
Old 03-24-2017, 07:31 AM
  #1435
Duke
Duke's Avatar
I don't really see how middle shaft twist would cause issues with a TC setup. It must be something with how the Motec algorithm is created.
In essense TC should work only by comparing wheel speeds between driven axle and non driven axle and adjust power delivery to get within a defined slip range.
In real life this will be extremely difficult to get done in a good smooth way with a high powered 4 cylinder turbo engine. For an 8 cyl N/A engine with DBW it should ve very easy though as you can just start cutting some of the cylinders alternatively to to reduce power smoothly. Very hard with turbo engine.
I've also been playing with a sophisticated TC setup (2 different manufacturers) and haven't been able to get it run smoothly. So I'm also running without.
With that said I haven't had the need in dry. To me it's a wet thing. Even with 750+ hp traction is good when you got the tires and the aero.
Old 03-24-2017, 11:28 AM
  #1436
TonyG
TonyG's Avatar
Which engine management are you using?
TonyG
Old 03-24-2017, 12:03 PM
  #1437
V2Rocket
Rainman
V2Rocket's Avatar
can't just do this with an ABS type system?
Old 04-02-2017, 07:05 PM
  #1438
Noahs944
Noahs944's Avatar
You've achieved the nicest side dump exhaust I've ever seen on one of these cars.
Old 04-02-2017, 09:53 PM
  #1439
V2Rocket
Rainman
V2Rocket's Avatar
yeah, thats a really clean/clever way of doing it, making the most of the space available..
Old 04-04-2017, 04:26 AM
  #1440
zeusrotty
zeusrotty's Avatar
A lot easier to do it that way with a 911 suspension under it.
Quick Reply: TonyG > New Race Car Build Thread
