996TT Calipers on Cayenne Rotors
Old 04-09-2012, 12:02 PM
xschop
xschop's Avatar
Default 996TT Calipers on Cayenne Rotors
Anyone have a spare 996TT caliper? I will design and build the adapters for them to mount on Cayenne 330 x 32 rotors using the 87-up spindle/hub....
Been searching Ebay and the for sale section here...nada
Old 04-09-2012, 05:18 PM
95ONE
95ONE's Avatar
I sent a PM.
Old 04-09-2012, 06:18 PM
xschop
xschop's Avatar
Edit. They will mount over the 350 x 34 Cayenne rotors
Currently I'm running the Lexus LS430 monoblock calipers over the Cayenne 330 x 32 rotors
Old 04-09-2012, 06:25 PM
anders44
anders44's Avatar
32/34mm rotors, with that wide pad with, is just dead weight on a 944.
Thick rotors, is really just for thick/heavy cars.
I bought the 996 C2/c4 rotors, (same as 986 boxster S) they usually take a 318x28 rotor, but I bought a full floating PFC 330x28 for fronts, and.. hmm I dont remember rears, but I have data somewhere.
Just gotto get the time to make drawings for machineing.
Both calipers, rotors, pads are lighter, and more than sufficient, I will run 295 fronts and 335 rears with this setup.
Good thing, is that the 996 calipers are cheap, and widely available.
Old 04-09-2012, 06:44 PM
xschop
xschop's Avatar
The Cayenne rotors are much cheaper. At first I was running the Boxster S rotors (318 x 28) and simply going to the Cayenne 330 rotor on the same calipers shortened my stopping distance and I had to adjust the rear brakes on my dual MC setup for even more stopping power....win...win
Old 04-09-2012, 06:47 PM
anders44
anders44's Avatar
Originally Posted by robstah
Thick rotors can also be a function of heat dissipation, which can make or break a street/track or track car. The rotor needs to be able to handle all the energy coming from the pads during braking, so heat doesn't spread to the calipers/brake fluid and even to the suspension parts. You would have better luck removing weight from the wheels than to do so with the rotors.
Thats why you have brake ducts/cooling, srf fluid and proper hoses.
Thick rotors will just save more energy, if you havn't got proper cooling in first place, heavy rotors will just postpone the problem.
On STOCK rotors/calipers I easily manage 30-45 min raceheats going 100% attack, *after* I gave them proper cooling and srf fluid, before it was hopeless.
Since I will be going widebody + the v8 I want the increased brake size, also weight is down, from stock setup, and the monoblock calipers are great little things.
Old 04-09-2012, 06:56 PM
xschop
xschop's Avatar
As for Piston sizes, the Lexus calps are still boss. The 996TT calipers/pads come from factory with deeper pads for the taller sweep area of the 350mm rotors and I've been asked to build them since I already machine the rotor rings.
Old 04-09-2012, 11:14 PM
95ONE
95ONE's Avatar
Nevermind.. he still needs calipers folks. Anyone?
Old 04-10-2012, 12:38 AM
JohnKoaWood
JohnKoaWood's Avatar
I have them, one temp fitted to the car, the other caliper and rotor are sitting in the garage.... Bought them last week from the FS member forum... For a song!
Shoot me another pm, maybe we can work something out for a set of adapters or something....
Old 04-10-2012, 12:51 AM
David Floyd
David Floyd's Avatar
How much are the 996tt calipers though? I doubt they are cheap.
As with anything shop around, I bought 996tt calipers, rotors and Pagid Yellows (1500miles on pads and rotors) for $650 shipped.
Old 04-10-2012, 09:31 AM
JohnKoaWood
I paid a little more, but with NEW 330mm slotted rotors and NEW metal ceramic pads...
Old 04-10-2012, 10:56 AM
JohnKoaWood
FWIW.. some might be asking why...
I didn't take a picture of the rotor thickness side by side, or pull weights of the pieces to compare, but this should work out quite nicely! and will still allow use of 17 inch wheels!
Old 04-10-2012, 11:37 AM
xschop
xschop's Avatar
Thanks John. So from the Pics, the 996TT should go on a 350 dia. rotor. I believe TonyG just put 350mm rotors under Cup 17's......
Cayenne 330 x 32
Cayenne 350 x 34
Old 04-10-2012, 04:07 PM
reno808
reno808's Avatar
I have 2 front 996 TT calipers let me know if you need to borrow it
Old 04-10-2012, 10:21 PM
David Floyd
https://rennlist.com/forums/showthre...&referrerid=38
Quick Reply: 996TT Calipers on Cayenne Rotors
