Brake Upgrade....86T Only
I'm going to chronicle what I'm doing to a 1-off BBK for the 86 951. Thicker yet Light-weight Wilwood rotors and billet hats.....10.5 LBs total compared to the all steel 951 rotor at 16.2 Lbs.......Built a set a few years ago and forgot what I did LOL. Dejavu......
Mill down the inner rotor sweep nodules to clear the 32mm thick rotor....
Take off 150 thousandths from the spindle ear interfaces....
Drill and countersink the hat (1.5 Lbs) to the Early Porsche hub PCD 127mm...
Drill and tap the Billet hat for 8 x 7" PCD for the Wilwood rotor (Weighs 9Lbs)
I had to trim 1mm from each side of the pad shims for the thicker rotors....
I always use Red Loc-tite on my Rotor/hat bolts, but I went the extra distance and cross-drilled each one for safety wire for whoever acquires this set.....
I lightened the hats even more by cross-drilling the thicker portions on the same 5 x 127mm pattern......T-6061 T6 hats will keep the heat off the hubs/bearings....
New piston seals installed and New OEM pads and Fresh VHT ceramic caliper paint. Also throwing in a fresh tube of Red Loc-tite for the hat/rotor bolts. Also changed the Hub/billet hat bolts to 5/16-24 Fine thread with full metal Locker Nuts just like the factory setup.... $550 shipped anywhere in the US-48....Just PM
This is a 1-off upgrade for the front ONLY. The Pistons are 36 and 38mm with new piston seals installed.
Everything is included for 100% Bolt-On...... Brand new Wilwood 11.75 x 1.25" directional rotors...
Wilwood 160-2898 1.25" X 11.75" X 7" Ultralite 8 Bolt Brake Rotor
$36.68
Wilwood 160-2899 1.25" X 11.75" X 7" Ultralite 8 Bolt Brake Rotor
$36.68
$36.68
$36.68
I machined it from a 911 top-hat I had on the shelf for a couple years. Removed even more weight from it with the perimeter holes that will radiate more heat away from the hubs.
These hats do not exist elsewhere as they are 8x7" PCD specifically designed for the Wilwood rotors. You could mount a 13" Wilwood rotor as well and adapt bigger calipers later if you choose.
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
i've been getting lousy braking to the rears. running GTS brakes in the front, i can get them to lock up. but not the rears... also i need to push down pretty hard to get good braking.... on the left rears, the rotors aren't shedding the small amount of rust that builds up near as quick as they should.... i haven't changed the fluid in a while [like, maybe 16 k miles]... still, i suspect my 19 year old rotors are, [as in, of course they are] shot.
running a 5-33 valve, but still never great braking back, there.
wondering if i'm better off with beefier rear brakes. preferably aftermarket.
thoughts ?
thoughts ?
