HKS EVC boost controller
Hello
anybody has a manual for this?
I bought a used one and it cam ewith NONE infos on wiring or whatever!
Konstantin
Konstantin
You didn't say what kind of EVC, but here are some online manuals:
HKS EVC IV:
<a href="http://www.speedtoys.com/~stryder/evc4install.html" target="_blank">http://www.speedtoys.com/~stryder/evc4install.html</a>
HKS EVC EZ:
<a href="http://www.alltrac.net/manuals/HKSEVCEZ.html" target="_blank">http://www.alltrac.net/manuals/HKSEVCEZ.html</a>
HKS EVC IV:
HKS EVC EZ:
anybody can help on this?
I have the HKS EVC2 but it ccame witout the wiring info AND the wire loom is cuted so I do not know what to hoock up and where.
I see two wire looms coming out of the rear of the EVC, one 9 PIN and another one 6 PIN.
The other one loom coming out of the valve has also 9 PIN. It looks diferent but the wires color are the same as the one on the smaller 9 PIN at the rear from the EVC.
What to do with the smaller 6 PIN coming out from the EVC?? Where does this conect? It must be for +12, groung etc but there are 6 wires!!!. it must be simmilar with the newer HKS units. Anybody who has experience with them?
There is no HKS shop in Germany so no chance to get infos here and I can not find any infos on the older EVC 2 on the web.
I include some pics in case someone can help with this.
Konstantin
PS John Anderson can you contact me? You are the only one that knows how this think works)
Konstantin
i have the evc 3 with complete manual and wiring hook ups. if you need be i could have it mailed/scanned and emailed to you. it would take a few days though. let me know if you are interested.
Sam - you think that info would be applicable to the EVC2? I have the installation manual, but it makes no reference to single-port wastegate setup.
Also - are you guys running moisture filters in the lines?
what i realy want to know is the pipe info on the solenoid valve. what is in which is for "out" and what is the third one for?
the third one is always open I can blow through it. I hope it is not damaged.
Konstantin
Konstantin
now I have the manual for the EVC2
it can be found at
<a href="http://www.hksusa.com/info/download.asp?id=1742" target="_blank">http://www.hksusa.com/info/download.asp?id=1742</a>
what is the difference between EVC1 and EVC2? it looks teh same to me
Konstantin
it can be found at
Konstantin
