baby steps part three: sway bar(s) and crossover pipe insanity
so, bit by bit i'm heading towards the oil pan gasket and a ton of other work on the front end of my car. to that end, and since i know it's a loooooong task, i've been doing bits here and there.
since our company gave us our "holiday bonus" early (actual wad of cash in an envelope), i went to sears and stocked up on big metric wrenches, flexible ratchet wrenches (BEST THING EVAR), a torque wrench, etc etc. these would all prove rather handy today, to say the least.
so, first i pulled out the brake system heat shield and turbo pump:
then i started on the crossover pipe @ the turbo.
seriously: what the hell was porsche thinking?!?!
i got the first three off (top and bottom towards front of car, top towards rear), but the fourth and last one stymied ALL attempts at removal. i think i need a stubby 17mm box wrench to get it, and even though i'm pretty strong, it's gonna SUCK pulling it out.
the other thing i was wondering about was the bolt sizes for this connection. everything was a different size, which was incredibly irritating when trying to do things by pure feel. i discovered:
top bolt, front: 15mm head and nut
bottom bolt, front: 15mm head and 17mm nut
top bolt, rear: 13mm head and 15mm nut
bottom bolt, rear: 17mm head
is this to be expected? :\
after a rage-building hour or so, i decided to do something that i could complete. how about the wastegate!
the 10mm bolts connecting it to the crossover came out easy, but the 13mms at the base were so incredibly close to the body, i nearly stripped the head of one before i stopped. a quick stop at clark's gave me some info that i'll be trying out...
i also noticed that i was missing one of those four bolts, as well. good times. more rage.
and here is the collection the tools i accumulated/used/tried to use during this exercise in seeing how pissed i could get:
now i'm at very high levels of fail, and now it's getting dark. time to really see if there was anything i could reasonably do w/o either killing myself, destroying the part, of breaking the car.
how about the sway bar? i'm replacing all of mine w/a set off of a 968 (base model), so the front has to come off regardless. another quick stop at clarks to confirm the simplicity paid off: 6 bolts later, and it's out:
i measured it w/my calipers and it's a hair over 24mm or so thick (looks like 24.5, but my calipers only have english units on the dial). looking again at clark's garage's sway bar table (here: http://clarks-garage.com/shop-manual/susp-15.htm), the closest match seems to be for an 85-91 m030 option 944 turbo.
is there a definite way to tell, other than the diameter? i didn't see a part number on it, and i'm unsure how to tell if it's (totally) tubular.
if it's indeed a m030, selling it should take a big bite out of the set i'm getting from the 968!
next installment: more rage, or how to take bolts out w/o going on a killing spree!
Basic Sponsor
968 M030 swaybar is 30mm
the two sites i've referenced from list the 1985-6 turbo m030 as having a 24mm sway (mine's an 86).
http://www.924.org/techsection/Suspe...reparation.htm
so, who knows. it's the internet and they could be wrong. i could call a local porsche dealer and ask their mechanics, or maybe pelican parts or something.
also, i'm not getting the m030 968 bars, just the regular ones (26.8mm).
Basic Sponsor
24MM & 25.5 are almost standard, what you consider desirable upgrade is the 26.8mm and the 30mm.
I just sold this one
http://cgi.ebay.com/ebaymotors/ws/eB...m=250721188405
and this is the 968 m030
i am upgrading to a 26.8, which should be arriving soon.
Basic Sponsor
I don't think anybody here would call the 24mm a m030, except the manual, I had always known the 24mm and 25.5 as the standard turbo swaybars. But don't listen to me Iam kinda of a noob
yeah, i liked the handling of the car when it was running -- but i did think the shocks were a bit soft (kybs will do that), and there was more body roll than i expected. i'm expecting the konis (m030 kit, all four corners), lowering springs (on the car currently) and thicker 968 bars will do the trick.
