1986 Porsche 944 turbo 951 FOR SALE asking $5,900 OBO
FS: 1986 Porsche 944 turbo 951 For Sale. $5,900 OBO
The rebuilt head and turbo. All new gaskets, water hoses, vacuum hoses, stainless steel hose clamps, and even new hardware were installed during this time. basically everything from the head up has been rebuilt. New fuel filter and check valve. Rebuilt injectors. millage of car is unknown. When i bought the car CarFax had a history of a rolled back odometer. The paint has some flaws in some spots and is definitely not perfect. The front nose panel between the head lights has damage. panel was backed into. No damage to intercooler or front structure, only to nose panel.
All of the following items have been removed: a/c, heater, a/c and heater lines, drivers door panel, rear seats, rear carpet, passenger windshield wiper, radio, a/c controls, window washer container. note: The cooling fans have been connected to a toggle switch. Which is located on the dash.
Engine:
Rebuild head.
valve guides and seels by Specialty Imports Fl.
Installed new head nuts and washers.
Cometic metal head gasket.
Lindsey racing head gasket set.
New rollers and tensioners from LR.
New belts. New vaccum lines and hoses. Venturi vaccum system delete.
Bored throttle body.
Nology ignition coil amplifier.
Huntley racing fuel presure regulator.
Jegs fuel presure gauge.
Factory K26/6 turbo rebuilt by CMR turbos FL.
Tial 38mm wastegate w/ 1bar spring(14.5psi).
Speed Force Racing wastegate adapter plates.
Lindsey racing 3in. Magnaflow high-flow 50 state legal cat and oval muffler .
I also have 3in. cat by-pass pipe and muffler by-pass pipe if you wanted to remove them .
Turbo smart manual boost controller (currently set at 15psi).
Lindsey racing boost enhancer.
Lindsey racing stage 2 intercooler.
A/C delete & heater system delete.
Optima red-top battery.
Lindsey racing remapped computer chip.
K&n air filter.
DEI heat wrap on headers, turbo, and down pipe.
Previous owner stated this car had upgraded clutch and flywheel but this i don't know for sure.
Body:
American International Racing. (Fiberglass hood w/ scoop).(Fiberglass front fenders).(Fiberglass front & rear bumper).(Fiberglass side rocker panels).(Lexan rear hatch in frame).
Interior:
Cobra drivers seat with adjustable frame rail.
Corbeau passenger seat with adjustable rail.
Sparco shift ****.
Sparco Aluminum racing pedals.
Short throw shift linkage.
MOMO steering wheel and hub.
Greddy Turbo timer.
AutoMeter gauges (Water temp. Oil Temp.).
HKS Boost Gauge.
Wheels:
Forged Racing (priced at $500-600 per wheel) 17" x 8.5" front17" x 9.5" rear
Tires: Sumitumo 235/40/R17 front. 275/40/R17 rear
Brakes: OEM Brembo 4-piston with about 70% pad left.
I also have 4 stainless steel braided braked lines brand new but not installed.
Suspension: All OEM turbo stuff. Koni adjustable struts Front & Rear. New steering rack bushings installed.
Call or email me if interested. I am asking $5,900 or make me an offer. I must sell fast.
Chris, 813-610-5393, x944turbo@aol.com I am located in Plantation Florida Area code: 33324
Engine:
Rebuild head.
K&n air filter.
Body:
Interior:
Sparco shift ****.
Greddy Turbo timer.
HKS Boost Gauge.
Wheels:
