What psi to use when pressure testing cooling system?
What psi do our cars run at when up to temp?
10psi - 15psi ok to test with?
Car left a spot of coolant on the ground so I pulled the fans and found this:
Just started leaking, radiator only has about 40k miles on it, hoses are all a year old or so...I tightened everything up and now have a pressure tester on it.
Thought it was the radiator at first but now thinking I might have gotten lucky.
thanks!
thanks!
The cap is a 1 bar unit (14PSI) so I wouldnt go much over that. I would go to 14 psi, I once had a tiny pinhole in a hose that I only found using high pressure (IIRC, 10 psi didnt make it leak, it was a tiny pinhole).
Test for whatever the cap is rated for. Unless the cap is stuck, the system will not see above its rating.
For a point of reference, on several occasions, I've pressurized the system to 25psi, so if you go a little over to 16 or so psi, I wouldn't loose any sleep over it.
+1 Definitely take it to 15psi. The cap is rated for 1 bar, which is 14.4 psi, so 15 isn't putting any stress on it, and since the object is to find a leak, it needs to be at the cap limit. I do this all the time and have never had an issue.
Depending on how involved you want to get into leak checking, one of the best way to find a leak is to test the system without coolant. While under pressure, spray water with a little bit of dish soap added. This will form bubbles where the leaks are.
I zip tied a plastic baggie over the end of the overflow hose, so that I can tell between overflow and leaks.
I generally use 15psi to check for leaks, letting it sit for while...
I just tested mine to 15 and let it stand for 45 minutes without any drop off. You may not see the leak but the drop off will be the real test. A real slow leak may take 15-20 min to show.
