Rennbay Fuel Line Basic Kit
Does anybody have any pictures of this kit installed? I bought this a year ago and I didn't get it installed yet.
http://www.rennbay.com/fuel-hose-rep...-855-p-61.html
What is difficult to do? If i have a shop do it is their anything I need to let the mechanic know? I plan on buying a new (944 110 413 02) Fuel Line Fuel Rail to Diaphragm Damper..
have an extinguisher on hand the first time you run it should be a no brainier .. always use 2 spanners for every connection to avoid damaging stuff .always try to arrange the 2 spanners about 15-45 degrees apart so you are pushing them together these reduces the risk of damage to the the rail etc due to reduced movement of the fittings
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
Seriously - good advice from down under. Fuel at 60 pst has to be taken seriously.
Sebastian, I did it and it was fairly easy. I didn't cut the return line. I was able to get the old press clamp out without cutting the line. I remenber that one of the hoses was more difficult than the other. Like it was mentioned above have a fire extinguisher in the car just in case something goes wrong.
Of course I had to cut to length. Also once I removed the old lines and found the protective tube also allowed air to pass between it and the fuel hose, I cleaned and reused it.
very interesting to compare, though mines not a turbo
Wait a second do i still need to replace the (944 110 413 02) Fuel Line Fuel Rail to Diaphragm Damper) when i have the Rennbay kit? by the looks of the picture the kit replaces that part too? or am i wrong?
I'll take some pics tomorrow.
