Home Made MAF
Old 12-16-2009, 01:46 AM
  #31
alxdgr8
alxdgr8's Avatar
Originally Posted by Rogue_Ant
That is not true.
You most certainly can run a MAF. Will it be 100% correct (without changing the transfer function code), no but it will work.
-Rogue
Well I haven't done too much reading into the ostrich, but the point of not being able to change the code was what I was getting at. So you setup the ostrich like a MAFterburner or such to massage the MAF signal?
Old 12-16-2009, 01:54 AM
  #32
Rogue_Ant
Small Business Partner
Rogue_Ant's Avatar
No, the Ostrich does not massage any signal. The Ostrich allows you to make changes to the DME mapping/programming directly. Anything that can be done with a chip, the Ostrich can do - but without the hassle of changing chips. I just hook it up to my laptop, make immediate changes and go.
-Rogue
Old 12-16-2009, 01:56 AM
  #33
alxdgr8
alxdgr8's Avatar
What I was getting at is how does the ostrich allow you to run a MAF without changing the code of the transfer function?
Old 12-16-2009, 01:59 AM
  #34
Rogue_Ant
Rogue_Ant's Avatar
The Ostrich is just a tool. The user still has to change the code.
Old 12-16-2009, 11:10 AM
  #35
toddk911
Drive-by provocation guy
toddk911's Avatar
Originally Posted by pormgb
I initially used this MAF but it was so big I had problems fitting it under the intercooler hard pipe, are there advantages using a larger MAF?
Well, I think to fit most MAF's close to the hedlight/intake fender hole, you need to do the headlight support cut/mod. It does not affect the headlight operation at all.
In any event the MAF housing itself is only a little bigger than other 3" MAF's.
Also, I have no cone as that takes a lot of room and does not allow direct intake of ambient into the MAF so I have the MAF inlet side wrapped in the standard paper filter (think like a drum head) and then placed right up against the fender snorkle hole.
The size of the MAF, from my research, makes a difference, but the flow capcity of the MAF sensor itself is more important in terms of clipping the 5V sig. I was clipping my old Hunltey so I got this one so I would not have to get another one. Wit hmy set up at full boost and WOT I see about 4.2-4.3v as with the Hunltey and less boost was seeing 4.8v+
Old 12-16-2009, 12:27 PM
  #36
spyder348
spyder348's Avatar
Default maf
todd the ford maf has a circle side and 4 bolt other side. what did you do with the 4 bolt side
Old 12-16-2009, 05:17 PM
  #37
toddk911
toddk911's Avatar
I bought it from someone else that had already modded it to fit by shaving down the 4 bolt side so both sides are round.
Going from the 3" Huntley MAF and cone to this MAF and paper filter wrap you can really hear the air get sucked in a lot more and I had to richen up the low end range alot as it obvioulsy brought in much more air in the lower revs than the previous one and spool up jumped a few 100 rpm.
Even with the laggy LR 75 turbo in 2nd with my 18x10 rears the back end will start to walk.
Old 12-16-2009, 07:58 PM
  #38
spyder348
spyder348's Avatar
yeah thats cool i could def shave off the flat part. So the maf works good huh? what about a cobra maf. i have been bench testing and making charts all day long of different maf sensors. trying to find a close match. what piggy back are you using.
Old 12-16-2009, 08:13 PM
  #39
PixxByTango
PixxByTango's Avatar
You guys are in need of better parts. Buy a Cobra or Lightning MAF and then use the A'PEXi SAFC II or Neo if you can find one. The SAFC II can be found for about $130 or less and the new NEO is about $350.00.
What this will allow you to do is completely tune your air/fuel ratio... regardless of airflow or boost levels. In the event that your car's ecu has a boost limiter, you can vent via checkvalve to the MAP sensor to do a boost peak, then via use of larger injectors, increase the fuel trim utilizing this tool. All the while maintaining full factory drivability and safety programming. The A'PEXi Air Flow Converters work by intercepting the signal between the car's air flow meter and the ECU.
The ECU calculates the proper ratio of fuel to air for a stock, unmodified engine. Certain engine modifications can cause the dynamics of the engine to require more fuel. In this case, there are two common options for modifying the amout of fuel being input into the engine. One can either install larger injectors or increase the fuel pressure to the stock injectors is increased.
Since the stock ECU thinks that it knows how much fuel it is putting into the engine based on the stock injector size and the stock fuel pressure, changing either of these will result in increased fuel. You may get lucky and just pick the perfect injector or fuel pressure that gives you the perfect air/fuel ratio. You may also get lucky and pick this weekends winning lottery numbers. In either case I wouldn't bet the farm on it. The Air Flow Converter gives you the means to adjust the amount of fuel that the ECU injects into the engine by modifying the signal from the air flow meter. This is done at specific RPM levels. This way you can tell the engine that a certain amount more air is flowing into the engine as a specific RPM than is really entering the engine, and the ECU will add that much more fuel. Decrease it at another RPM level and the ECU will decrease the fuel into the engine. It all boils down to identifying the correct wire into the ECU. In general, the following wires must be identified:
•Ground
•Power
•RPM
•Air Flow / Pressure Signal Input
•Air Flow / Pressure Signal Output
I have doubled the boost on my Yamaha Waverunner utilizing this tool and on many other vehicles where MAP or Air Metered functions control my fuel enrichments.
This is directly from the A'PEXi website:
The AFC NEO is unique in the sense that it has a built in MAF/MAP transfer function, which is necessary when the tuner swaps MAF/MAP sensors from one vehicle application to another. By setting the sensor IN and OUT to the appropriate sensor numbers, the AFC NEO can act as a translator/emulator unit, eliminating the need for costly sensor or ECU reprogramming.
http://www.apexi-usa.com/products/?id=5347
Old 12-16-2009, 08:16 PM
  #40
alxdgr8
alxdgr8's Avatar
Screw all the "bandaid" ways of putting together a MAF kit and do it right...
...Standalone!
Old 12-16-2009, 08:20 PM
  #41
PixxByTango
...Standalone!
Sure... throw a $3500 Motec at it. Now... who is going to make up the harness, baseline tune it and take responsibility for popping the engine? Oh wait... where's the knock sensor? Oh yeah... that's another $1500.00 Wideband OPTION!
Use the method I prescribed above and you can build a 400+hp engine with daily drivability in the separate map functions. Meaning.... you can have a Racegas map and a Street economy pump gas map.
Old 12-16-2009, 08:26 PM
  #42
spyder348
spyder348's Avatar
thanks for the post the neo looks good. ill look for the safc 2 for the cost.
Old 12-16-2009, 08:30 PM
  #43
PixxByTango
The Neo is overkill and its simply for the ricer wannabe's needing the new latest and greatest. That should flood the market with lots of SAFC2s out there. I received my last one for FREE from a Subaru guy changing his set-up to a standalone system. It has currently served me quite well on my Yamaha. I will however be purchasing another one for my O.J. Bronco that has one helluva cam the Speed Density tuning hates at idle.
Old 12-16-2009, 08:35 PM
  #44
alxdgr8
alxdgr8's Avatar
Was a joke of a post, but...
Plenty of other options out there besides Motec. Link G4 extreme has knock monitoring. There's a certain guy in chicago that make harnesses for the 951 too.
Then there's megasquirt too...
There's always the cheap way and the right way to do things.
In all reality, everyone should just go back to running MAFs with ARC2's!!!
Old 12-16-2009, 08:50 PM
  #45
CPR
CPR's Avatar
There is also a big difference between a Yamaha Waverunner and a 951
Quick Reply: Home Made MAF
