Autothority MAF question
I recently acquired a Autothority MAF fairly cheap and the wiring harness was cut.
I have the side of the harness that plugs into the MAF, but missing the side that plugs into the car. I have searched around the forums and found a wiring diagram and picture, but mine seems to be a newer model MAF. My MAF has a built in air intake sensor rather than a potentiometer. The part number on this is HWS.02.951.100.
What would be helpful would be a wiring diagram or someone telling me what colored wires go to what colored wires and pictures.
The wiring diagram that I am speaking of for a old style MAF is located at https://rennlist.com/forums/5520518-post1.html
Like I said that has the potentiometer in it, where as mine is a real AIS.
Thank you very very much!
Zach
Zach
Zach, In the picture you posted a link to, the Potentiometer is taking the place of the IAT you have on your system. Unless you have a modified APE chip, the potentiometer might be the way to go. Also, in the picture there is a wire missing from the MAF plug. You should have 4 wires. The middle 2 wires are ground wires and should be connected together. (in the picture the second ground wire is missing).
Hope this helps.
Hope this helps.
Thanks for the input John.
The harness that I have, only has three wires as well. I not sure why a potentiameter would be better than a real IAT that can automatically adjust.
Like I said a picture of the new Autothority wiring harness would be wonderful.
