Help! Car leaks gas after fill up. drip...drip...drip
My 1987 951 has a problem! I went to the gas station to fill it up today. Everytime I filled it up all the way, I would bring it home, let it sit in the garage, and in about an hour, the garage smelled like gasoline really bad. Today, I filled it up all the way and looked under the car when i got home and it was leaking. The was gas dripping from the gas tank location. It was a drip every 3 seconds. Has anybody had this problem and what could be the cause.
thanks, Dillon
thanks, Dillon
http://www.clarks-garage.com/shop-manual/fuel-10.htm
If it only does it with a full tank, the problem might be in the filler tube components.
951s also sometimes leak gas in the engine compartment, usually the fuel rail. Then they catch fire.
It doesn't sound like that's your problem, but look for it and smell for it.
thanks, Dillon
thanks, Dillon
George
could also be a bad fuel pump o ring (bad fuel pump for most, but I chose to change the o ring)
I had it start doing that right after filling up once ... couldn't figure out how it was related but that was the problem.
