Exhaust Hanger Orientation
For the hangers that hold up the exhaust pipes and muffler, do the top and bottom hangers both point the same way so that the rubber donut pushes onto both in the same direction -- or should the top and bottom hangers point in opposite directions?
Well, a data point of 1: I had one set of hangers facing the same direction, and just discovered that donut fell off. The other hangers faced in opposite directions and those donuts are still there. Anyone with an uber-original car care to take a look-see?
Edit: all the illustrations in PET seem to show the upper and lower bracket pieces sliding into the donut from opposite sides too.
1. Top and bottom hangers oriented the same way:
a) Depending on how much the top and bottom hangers are misaligned in either direction the rubber can potentially slip out.
b) If the hangers don't provide a good stop for the rubber in the open direction, then the rubber can "walk out" on its own.
2. Top and bottom hangers oriented in opposite directions:
a) The rubber can potentially slip out only if the top and bottom hangers are misaligned in one direction .
b) Even if the hangers don't provide a good stop for the rubber in the open direction, their opposite mounting will prevent the rubber from "walking out".
So opposite hanger mounting seems to be the best solution.
I was recently "in there" and just decided to copy the previous install, which obviously was same direction of the hangers ... oh well maybe next time.
Laust
That's actually a bit of a brain teaser.
Laust
Laust
If you bolt it up like that, the donut is constantly being pulled onto both brackets, if that makes sense...
Funny how easy it is to get caught up in the most "mundane" things with these cars. Was actually just in that area yesterday as I painted a rusty hanger a nice satin black.
