1986 Porsche 944 Turbo
5th Gear
Heres my 951... Thought i would post it on here.
MODIFICATIONS:
•Kokeln Stage 5 turbo
•Kokeln racing Chips
•Kokeln larger injectors
•Kokeln IC hard pipe kit
•SFR 3” SS Cat back Exhaust
•Turbonetics Delta Gate
•LR Breather Kit
•Manual boost controller
•Auto Meter 30psi boost gauge
•Auto Meter Air\Fuel Gauge
•Fuel pressure gauge
•Adjustable fuel pressure regulator
•Carbon Fiber interior dash kit
MAINTENANCE:
•Complete engine rebuild @ 97,936
•Rebuilt Rods (new bolts & pin bushings)
•New main & rod bearings
•New Piston rings
•All new gaskets, top & bottom – NO LEAKS
•Wide Fire head gasket
•Valve job & resurface
•New OEM ignition cap & rotor
•Magnecor 8.5mm spark plug wires
•NGK Iridium spark plugs
•New LR vacuum hose kit
•New OEM intake hoses (Venturi delete)
•New fuel & oil filter
•New thermostat
•New OEM TPS Switch
•All belts (aprox. 5k mi)
•All tensioners & rollers (aprox. 5k mi)
•New Tires
•Rebuilt rear axels
•New bypass valve.
•Expansion tank hose
•Cross drilled rotors & Pads
•ATE Super Blue brake fluid
•Sachs 951 Cup Car Clutch (Aprox. 8k mi)
•New Trans output seals & Oil
•LR aluminum Trans mount
•New engine mounts
MODIFICATIONS:
•LR Breather Kit
MAINTENANCE:
•New Piston rings
•New thermostat
•New OEM TPS Switch
•New Tires
•Rebuilt rear axels
•New bypass valve.
•New engine mounts
Official Rennlist
Borat Impersonator
Borat Impersonator
beautiful car!!!!
just wondering why you still have an AFM after all the upgrades you did? You don't like good throttle response??
5th Gear
Yeah... there is more I would like to do to it but I'm getting married soon and dont really have the extra money to dump in it. Even with the AFM and cat it still runs really strong. Unfortunatly i'll be selling it here soon.
