Megasquirt Injector Question?
Hello,
Went to do the final wiring harness prep and found I had wired injector bank 1 to injectors 1 and 4----and bank 2 to injectors 2 and 3(like the wasted spark).
I wired a Wolf3d years back and thought that bank 1 went to 1 and 2 and bank 2 to 3 and 4.
Any comments appreciated---
Cyrus
Cyrus
My factory harness is wired with Injectors 1 and 2 together and injectors 3 and 4 together.
I'll double check the harness again tonight, but I'm 90% that is the case. I'm not sure why it was done this way, but thats how it was.
The Haltech I am doing now is wired for Batch fire (1 & 4 together and 2 & 3 together).
1 & 4 together and 2 & 3 together is the way to do it unless you're doing sequential injection.
Adrial--thanks----the Megamanual shows 1 and 2 together also----Matt at DIY said he has seen cars both ways---and can tell which is right from the idle----it would seem to me that with wasted spark you would want 1 and 2 together---but who know---maybe with wasted spark you get better boost if 1 and 4 are together??
