The Official Venturi Delete Thread
Old 05-25-2010, 02:49 PM
  #46
ehall
ehall's Avatar
Did you unplug the TPS at some point and forget to plug it back in?
Old 05-25-2010, 06:35 PM
  #47
Paulyy
Professional Hoon
Paulyy's Avatar
6:30 in the morning, problem solved, throttle cable held the TPS open. thanks anyway fellas
Old 05-25-2010, 06:39 PM
  #48
ehall
ehall's Avatar
Thought so. Glad it's fixed.
Old 08-31-2010, 04:39 PM
  #49
Paulyy
Professional Hoon
Paulyy's Avatar
Just wondering, what is this blue and black thing, and does it just float around like that or it actually connects to something?
Old 08-31-2010, 05:50 PM
  #50
azbanks
Freedom Enthusiast
azbanks's Avatar
I can't tell you what it is but yes, it does not really connect to anything. Mine is part a a bundle of wires/vacuum lines zip tied too the firewall.
Old 08-31-2010, 07:17 PM
  #51
RENEE_J
RENEE_J's Avatar
The blue and black thing is a Vacuum Check Valve (928-537-361-02) connected in line from the brake booster, supplying vacuum to the recirculating air valve (climate controls), vacuum reservoir and heater valve.
Old 09-01-2010, 01:16 AM
  #52
Paulyy
Professional Hoon
Paulyy's Avatar
where are they located?
so in other words, it's not supose to be left laying there?
Old 09-01-2010, 11:04 AM
  #53
86 951 Driver
86 951 Driver's Avatar
I know this shows you how to not use a kit, but should these hoses be replaced since they are so old and rubber?
Old 09-01-2010, 12:54 PM
  #54
Paulyy
Professional Hoon
Paulyy's Avatar
i replaced mine and used their diagram for a mbc with a dual port wg.
only replaced them because because my lines kept popping off on boost.
but the check valve just hanging there dosnt seem right. the car drives fine and idles good, nice and stable.
Old 09-01-2010, 01:08 PM
  #55
86 951 Driver
I am going to do this and hopefully it will fix my boost problem.
Old 09-01-2010, 01:20 PM
  #56
black944 turbo
black944 turbo's Avatar
Pauly, it is supposed to b ziptied on the fire wall with a bundle of the harness and some other vacume lines as others have said.
Old 09-01-2010, 02:04 PM
  #57
ehall
ehall's Avatar
Generally yes.
Old 09-01-2010, 02:45 PM
  #58
Paulyy
Professional Hoon
Paulyy's Avatar
It's just so odd, but thanks for the info, i had to double check that.
Old 11-05-2012, 11:25 AM
  #59
txhokie4life
txhokie4life's Avatar
Old thread -- but I'm hoping this is still appropriate question.
Can you remove the ICV all together.
I'm doing a minimalist vacuum setup for my 90% track car (although it needs
to drive to/from the track).
For the moment I pulled the ICV and placed a 1/2" plastic pipe between
the two LR silicon lines.
Here is the picture just prior to me pulling the ICV. I was wondering on direction
and thought -- why do I have it in there at all :-)
thx,
Mike
Old 11-05-2012, 04:07 PM
  #60
andycowman
andycowman's Avatar
I cant tell you the impact on your set up but i am running an emerald ECU and currently have the ISV still in place but the ECU is ignoring it and controlling idle using ignition timing alterations. It idles perfectly well like this - I am also tempted to remove the ISV from the car as part of tidying up the vac lines.
Quick Reply: The Official Venturi Delete Thread
