The Official Venturi Delete Thread
Old 01-24-2008, 02:47 PM
  #31
Techno Duck
Techno Duck's Avatar
Just for clarification, if i am going with a manual boost controller and dual port wastegate...
1. I can delete the cycling valve, and also remove the three metal pipes completley?
2. Run one single 3/4 inch line from the AOS to the j-boot, and plug the bottom hole on the j-boot.
If i want to stop the slight smoke on boost, i have to get the late style hose with check valve that was on '89 and later cars (944.107.311.03), otherwise i can use generic 3/4 silicone (or rubber) hose?
Sorry if this is has been beat to death, but reading all of these diagrams and part #'s is driving me nuts!
Old 01-24-2008, 02:53 PM
  #32
reno808
reno808's Avatar
yeah delete the CV if you want to remove those 3 metal pipes you either need to replace the aos pipe with a rubber one or add a catch can which will also help with the blue smoke.
Old 01-24-2008, 04:10 PM
  #33
Trucho-951
Trucho-951's Avatar
The check valve on the AOS hose will not prevent smoking under boost, it's function is to pop open if the AOS hose ever gets clogged, giving the crackcase pressure somewhere to escape. So, even if it's not required, the factory thought it is a good idea for safety. If you decide to go with the checkvalve, make sure it is on the AOS side of the hose, because placing it on the j-boot side, renders the checkvalve useless.
  #34
jasonlp
jasonlp's Avatar
Very newb question but what are the benefits of the delete?
Old 01-24-2008, 05:14 PM
  #35
black944 turbo
black944 turbo's Avatar
I have factory hoses with no check valves, I bought mine 4 years ago, but they are factory hoses. Do I need a check valve? I don't see any reason.
Old 01-24-2008, 05:17 PM
  #36
eniac
eniac's Avatar
One less thing to cause a vacuum leak and in the process of deleting you can take care of a mess of hoses that will cause a headache later when attempting to troubleshoot a leak.
Old 01-24-2008, 05:22 PM
  #37
jasonlp
jasonlp's Avatar
sweeeeeet
Thanks! much appreciated
Old 01-26-2008, 09:57 PM
  #38
billthe3
billthe3's Avatar
No, you do not need the check valve. However, having the check valve can be good over time because it prevents oil sludge/crap from building up in the metal control line pipe, which would then block off the OAS and make the car burn oil out the exhaust (or something like that...).
Old 01-27-2008, 02:56 AM
  #39
Airflite40
Official Rennlist
Borat Impersonator
Airflite40's Avatar
I have an extra brand new factory hose with check valve if anyone needs one....pm me!!!
Old 11-26-2008, 03:14 PM
  #40
Richgreenster
Richgreenster's Avatar
Just to update this a bit. I found a hose at checker for $11.99 that replaces the ICV hose (951.110.217.01) (Picture #8 on the top of this post). I had to cut off 1 3/4" off of the end that attaches to the ICV and some off of the turbo intake side. (mine is modified so I cant say exactly what it would be for each of you but it is very easy.) This hose was just so close of a fit that I had to let you guys know to save a few $$$. It even bends arount the turbo to intercooler pipe and when adjusted just right it does not even touch on thing in the tight space.
Attachment 317808
Attachment 317809
Old 11-26-2008, 11:53 PM
  #41
TurboTommy
TurboTommy's Avatar
Does anybody know what that factory restrictor in the hose (I think it's the hose between ISV and the intake) is for?
Those of you that are using venturi delete; are you retaining that restrictor?
It seems like it saves the ISV somewhat upon suddenly closing the throttle; or what else could it be?
Old 11-27-2008, 12:46 PM
  #42
black944 turbo
I have a factory porsche ventury delete and there is no restrictor in mine. I bought mine 5 years ago from porsche. I am not sure why they have the restrictor on the newer ones.
Old 11-27-2008, 04:21 PM
  #43
TurboTommy
TurboTommy's Avatar
Well, if you have a venturi delete, factory or otherwise; that's probably why you don't have the restrictor.
I'm saying I have the original air routing, and I'm wondering why they put that restrictor in there.
Old 11-27-2008, 07:34 PM
  #44
black944 turbo
Some of the later ventury delets have some sort of extra piece that mine does not have. I thought that was what you were refering to.
Old 05-25-2010, 10:11 AM
  #45
Paulyy
Professional Hoon
Paulyy's Avatar
Hey, i have a question that i havnt seen here yet.
i just did the venturi delete with the Lindsey Racing kit and folowed their diagrams (also its abit different then the stock set up) but the issue is when i turned my car on the idle was sitting at 2100 and when i took it for a drive, when i changed gears the car would pull abit with out me touching the accelerator. and when i let go it would take a few seconds longer to drop the revs. can anyone help me???
also i have the folowing mods:
- Tial 38mm dual port wastegate
- manual boost controller on 15 psi
- AFMLink piggy back (MAP Sensor)
Cheers, Paulyy
Quick Reply: The Official Venturi Delete Thread
