Best Spark Plugs?
Old 01-07-2006, 09:05 PM
Northernwish
5th Gear
Northernwish's Avatar
Default Best Spark Plugs?
I'm going to be replacing my spark plugs. Car (1988 944 Turbo S) is daily driver, no track use. Any comments on what spark plugs are the best?
The Denso Irridiums are supposed to have a hotter spark at lower voltage than platinum ones, so I'm kinda leaning towars those at this point.
Thanks in advance for your help!
Old 01-07-2006, 09:26 PM
minas
minas's Avatar
NGK BPR7ES
Old 01-07-2006, 09:27 PM
HIGHBOOST
HIGHBOOST's Avatar
try to get a plug that is 2 heat ranges Colder than stock
Old 01-07-2006, 09:39 PM
streckfu's
streckfu's's Avatar
Originally Posted by minas
NGK BPR7ES
Look no farther.
Old 01-07-2006, 09:59 PM
special tool
special tool's Avatar
NGK BPR7ES
Old 01-07-2006, 11:32 PM
Chas
Chas's Avatar
NGK BPR7ES
Old 01-07-2006, 11:47 PM
streckfu's
streckfu's's Avatar
Platinum +4
Ok, seriously. Don't. I mean it!
Old 01-08-2006, 12:11 AM
eclou
eclou's Avatar
Received 1,165 Likes on 574 Posts
NGK BPR7ES. Know it, learn it, live it.
Old 01-08-2006, 12:28 AM
Eyal 951
Eyal 951's Avatar
NGK BPR7ES
Old 01-08-2006, 12:35 AM
Zero10
Zero10's Avatar
Bosch wr7dc?.... Champion RN9YC, I've run them both with great luck.
Old 01-08-2006, 01:21 AM
EdC
EdC's Avatar
If you search this topic you will find many threads, with some complaints that the tips of some Bosch plugs have broken off. Also I believe you will find dyno results that the NGKs were worth some hp over other brands of plug. And they are relatively cheap. See http://www.sparkplugs.com/Default.asp
Old 01-08-2006, 03:42 AM
Northernwish
5th Gear
Great, thanks! Seems as though the overwhelming favourite by a mile are the NGKs.
I also found a thread at Pelican Parts regarding the problems with platinum and the benefits of copper:
http://forums.pelicanparts.com/showt...ght=NGK+BPR7ES
Old 01-08-2006, 04:05 AM
DFASTEST951
DFASTEST951's Avatar
I've broken off the Bosch tips before. I just put in Champion copper. Work fine. Can anyone tell me what the differences of the NGK's are?
Old 01-08-2006, 07:05 AM
EdC
EdC's Avatar
Ask Special Tool as I think he had the dyno experience.
Old 01-08-2006, 10:27 AM
lart951
Basic Sponsor
lart951's Avatar
NGK BPR7ES .26 gap
Quick Reply: Best Spark Plugs?
