pin assignment on main harness / engine harness connection
Old 05-21-2005, 03:14 AM
turbite
turbite's Avatar
Question pin assignment on main harness / engine harness connection
Anyone have the pin assignment or diagram on the connection between the main harness and the engine harness.
I've got a generic main harness, and I want to hook it up to the stock configuration engine harness through the normal connection. (14 pin, but looks like only 10 are used)
Pins 1,7,12,14 don't have pins on my engine harness.
I can't find what I'm looking for in the manual, but then again, I can't find much of anything in the manual.
Old 05-21-2005, 09:05 AM
Chris White
Rennlist Small
Business Sponsor
Chris White's Avatar
its in the manual - you just have to trace the lines!
Chris White
Old 05-22-2005, 08:00 PM
turbite
turbite's Avatar
Hey Chris,
What I don't understand is how the drawing shows an 8-pin connection.
If I knew what lines to trace, I wouldnt be posting.
http://metaloft.com/pics/951/tech/87...ram_Sheet3.JPG
Old 05-22-2005, 11:50 PM
Chris White
Rennlist Small
Business Sponsor
Originally Posted by turbite
Hey Chris,
http://metaloft.com/pics/951/dashcircuitdraw.JPG
yer lookin’ at the wrong connector on the diagrams.
Check out the page entitled “944 turbo Model 87 Sheet 8” at location F 48-49, it called “DME Connection Plug” This is the 14 pin connector located on the fire wall in front of the central electrics box. A very handy connection point for experimenters and diagnosing problems.
Chris White
Old 05-23-2005, 01:55 AM
turbite
turbite's Avatar
Excellent!
Thanks Chris!
edit (for other readers):
After a brief glance:
1) coil
2) DME relay
3) DME relay
4) fuel pump
5) DME relay
6) instrument
7) start / ignition
8) instrument
9) instrument
10) instrument
11) turbo waterpump relay
12) none
13) instrument
14) none
Diagram is here:
http://metaloft.com/pics/951/tech/87...ram_Sheet8.JPG
Quick Reply: pin assignment on main harness / engine harness connection
