Easiest access to bellhousing ground?
Old 01-11-2005, 01:43 AM
Tom M'Guinn
Tom M'Guinn's Avatar
Default Easiest access to bellhousing ground?
What's the easiest way to get at the bellhousing ground, to clean it up?
Old 01-11-2005, 04:01 AM
Sam Lin
Sam Lin's Avatar
It's not unreachable from the top of the engine, stand on the passenger side of the car and reach in there, gently push the various wiring harnesses and heater valve out of the way and reach in there with a piece of sandpaper taped in a loop, wrapped around a finger to do the cleaning. Remove the bolt for the ground with a long extension from the driver's side of the car. Stuff the clutch hole with a rag before you start so you don't drop that bolt right into it.
Sam
Old 01-11-2005, 04:19 AM
Tom M'Guinn
So I should be able to get to it without removing anything else?
Old 01-11-2005, 04:23 AM
mark944turbo
mark944turbo's Avatar
pretty much, yea. You may have to take a few clips and various things loose, but you can get to them.
Old 01-11-2005, 03:11 PM
azmi951
azmi951's Avatar
dont drop the bolt it may fall in the bellhousing!!!!!!!!
Old 01-11-2005, 04:32 PM
jerome951
jerome951's Avatar
And don't let your socket fall off the end of your extension into the bellhousing!!! BT, DT.
I've found the flexible shaft of my Dremel tool with a wire brush on the end works really well for cleaning the bellhousing around the stud. I usually lay over the driver's side fender for access.
Quick Reply: Easiest access to bellhousing ground?
