Removing lower half of rear seat?
I'm removing my rear seat and have taken out the two inner seat belt bolts. Is there anything else that is holding it to the car?
I read that you just need to pry the seat off at this point but didn't want to risk damaging it.
Thanks!
Thanks!
Rainman
there is a LOT of glue holding the cushion to the car metal.
luckily it isn't super sticky at this age and so with good pulling it lets go without ripping up the seat foam.
at the top edge (where the seat meets the trunk floor) there are a few metal clips holding the vinyl to the trunk floor, remove those and then you can reach down behind that "flap of vinyl" that was clipped down to start separating the seat from the car.
