'86 944 NA no fuel no spark no start
Hey Rennlister's
I got a no start issue the fuel pump doesn't run on cranking put a new DME relay in I also have no spark from the coil. I can jump the DME relay and make the pump run. Reference and speed sensors are good.
Any advice would be greatly appreciated!
Thank you!
Thank you!
That sounds like the DME unit. Try tapping the DME with the back end of a screwdriver while starting the car. If it starts you can try repairing bad solder joints on the DME. Here is a video of the DME stuff if that turns out to be it.
Fixxed!
Hey Rennlister's
Thank you!
Thank you!
I did an entire drivetrain rebuild new torque tube bearings from Black Sea R&D and a new clutch and flywheel I replace the flywheel with a lightweight fidanza which ended up being three millimeters smaller in diameter than the factory flywheel so I had to adjust the reference sensor Pin to accommodate for that did that this morning and she fired right up!
