You can PlastiDip your whole car with spray cans for under $100 and it look awesome!
#46
That looks great! I'm not a big fan of blue cars.... But I think you may have something there!
It sounds like the dupli over plastidip s the way to go!
On a side note..... Has anyone replaced the plastic molding around the sun roof.... If so where did you find it???
Mine is a broken and sun damaged mess.... I tried clamping and glueing but it was less then successful..... I'm currently am thinking of pulling it off and running with out it.... The felt gasket is also long gone.... From what I can tell they dont really keep rain out as much as limit wind whistle.... Any bright ideas that don't cost hundreds of dollars???
Thanks!
Fred
Thanks!
Fred
#47
On a side note..... Has anyone replaced the plastic molding around the sun roof.... Mine is a broken and sun damaged mess.... I tried clamping and glueing but it was less then successful..... I'm currently am thinking of pulling it off and running with out it.... The felt gasket is also long gone.... From what I can tell they dont really keep rain out as much as limit wind whistle.... Any bright ideas that don't cost hundreds of dollars???
#48
You Sir, are the man! For $67 I am in!
I am 90% sure I'm gonna dip mine..... Which is a $500 parts car (ok... Now $2500 after work and parts to get it running and roadworthy!) it was a Florida car so no rust... (And the Blessed God of Galvanization!)
But the paint is severely sun damaged, particularly on one side.... So until I can afford a real professional paint job.... I think this may be a damn good alternative to doing a half assed "Earl Shive" paint job!
When ya get yours done..... Pics or it didn't happen!!!
Thanks!
Fred
Thanks!
Fred
#49
Got some new stuff to try today.
Was at home depot and they only had plasti dip in black and white so instead I got a can each of the following.
Rustoleum peelable primer- Anyone try this?
The can says "only been tested to work with rust oleum spray paint"
I wonder if that includes their flexidip? Although I guess its cool if you can spray over it with regular rustoleum. That really gives you some color options.
I also got rust-oleum felxi dip Gloss Top coat.
And Flexidip in grey.
Really wanting to do my red 944 in a different color but hate the look of different color door jams etc.
#51
#52
I'm thinking of matte black with a coat of clear.....
But.... Just found "Black Cherry", interesting.... Looks pretty close to my cars "Garnet Red"! I just ordered a can to try as a test!
#53
Ok, so I'm at a bit of a loss here. I've thought about this a bit, and I now can't decide what to do. The texture on the dupli over plasti job on the sunroof is a lot rougher than I think I'm up for now that I've lived with it for a few days. And the current paint is crap, so going back to it isn't really a plus, at which point I'm starting to think that I should maybe just do a DIY paint job instead, since the price and prep isn't that different. Ugh. Too many options!
#54
Here's my take, my $0.02, one person on the internet's useless opinion....
I've personally seen much smoother finishes spraying dip than what I've done with cans. They do have a new "pro-line" series that is another level smoother but requires a $300 gun instead of the $160 gun.
So.... for a more finished look I'd say you were in for a min. of ~$350-$450 initial investment (that's a base hvlp sprayer and 3 gallons of dip). (I've found I enjoy this goofy stuff as entertainment and thus it's $200-$300 to do another since I play with pearls).
If you don't have access to a big compressor (which has been my own sticking point) that's ~$800-$1k initial investment (compressor, gun, paint).
Personally I generally do every bit as much prep as one might do to spray regular paint so that's a wash....
At some point I'll try out spraying regular paint as an expansion of my car playing but I've had trouble breaking over that initial investment and comfort zone so far..... As far as not returning it to original, I wouldn't worry about that, the cars that had awful paint jobs I treated the prep like I would have to spray acrylic, sanded, bondo'd, etc. The last couple started multiple colors. I just happened to use Dip as it's better "paint job" much like our OP. And if you wanted to change the color after you don't HAVE to peel it off, you could just as well spray over it (for 2-3 jobs according to DYC).
Last edited by sobamaflyer; 03-20-2017 at 12:43 PM. Reason: oh yeah, on already bad paint
#56
An update of my product testing.
I sprayed my lap top with 4 coats of red Flexidip. It looked good. I then sprayed 4 coats of flexidip gloss coat and it looks amazing. It matches perfectly my red 944 that at some point was painted by I assume macco so I am not sure its exactly guards red.
One thing I don't like is that I did this on Saturday and still today it is just a bit tacky. Very minor however it is a dust collector. Very easily removed with a wet paper towel [rung out] but still cant imagine what my car will look like after sitting in the garage a few days. Are people having this issue with plasti dip glosses?
2nd things.
THIS IS VERY IMPORTANT AND SHOULDN'T BE TAKEN LIGHTLY.
I sprayed my lap tap in my garage with the door open. I layed the lap top on a card board box on the lip on my garage that meets my driveway. So I essentially thought I was outside.
I sprayed 8 total coats leaving each coat to dry for 5 minutes. The smell was pretty strong but not crazy.
20 minutes after I was done my throat started bothering me. 5 days later I went to the doctor to find out I probably have a chemical pneumonia, and if I waited another couple days I probably would have needed to go to the hospital.
I have of course researched chemical pneumonia AFTER I got it but it doesn't seem to be that uncommon.
I have also of course researched breathers AFTER I got sick. So please guys even if you think you don't need it. Invest in a 20 dollar breather. Could save you tons of many and health concerns later.
2nd things.
#57
Holy Crap! Sorry you got poisoned! I usually wear a breather but not always, will certainly make it always now.
Tacky: Yes, dip thing.... I have a bottle of dip protectant that makes it slick, I reapply every few weeks. I've read turtle-wax ICE spray is the same stuff but haven't used it yet to try.
#58
2nd things.
2nd things.
#59
#60
Cool! Must watch that later, I've been interested in trying this myself after seeing a chrome Audi go by a few weeks ago :-D
