944 & 944S Forum 1982-1991
Flipping headlights
Old 11-16-2016, 08:58 AM
C531XHO
C531XHO's Avatar
Default Flipping headlights
Hi All
So I have just change the belts on my 83NA and in doing so I disconnected the battery and hand cranked the lights up a bit to allow me to remove/replace the airbox inlet tube from the inner wing. Having completed the job and test started the car everything seemed great so I packed up my tools etc ready to go back in the house. As I was leaving the car the headlights began flipping up and down without stopping - clearly she was pleased with the new belts
I suspect it has something to do with the limit switches/contacts - I noticed when cranking the lights up that there was some resistance in the mechanism but thought it would sort itself out when the power was back on but seems not. Does anyone have any ideas what to try?
David
Old 11-16-2016, 02:16 PM
C531XHO
C531XHO's Avatar
Update - So far so good, ran out of time when the lights were operating by themselves and just disconnected the battery and left it. Went back to the car 3 days later and connected the battery - no light issues at all, GREAT!
Old 11-18-2016, 11:31 AM
Schmooey
Schmooey's Avatar
I'm wondering if the relay for the flip up motor was malfunctioning and after it sat without power for a while, it is working again? May be worth a new relay just to make sure it does not happen again.....
Old 11-18-2016, 01:29 PM
C531XHO
C531XHO's Avatar
Yes I will keep an eye on it, so far so good. I have sought to appease the 944 gods with a gift of many other parts in the meantime..
Old 11-18-2016, 06:10 PM
Schmooey
Schmooey's Avatar
Ah yes, a technique I've been doing a lot of recently...
Old 11-19-2016, 07:04 PM
NoRush993/951
NoRush993/951's Avatar
Yes most likely the relay. You can tap it with the handle of a screwdriver and get it working again sometimes. Once it starts failing, I found the flip returns and the relay will need to be replaced. Inexpensive part.
Old 11-21-2016, 05:15 AM
C531XHO
C531XHO's Avatar
Thanks I will put it on the endless list
Old 11-27-2016, 11:47 AM
MG944
MG944's Avatar
Just a quick idea if it ever happens again, pull the relay next to the connector on the headlight motor itself. Then you just have manual lights and can drive home in the dark
Old 11-28-2016, 06:16 AM
C531XHO
C531XHO's Avatar
Thankjs, good idea, I will tuck that away. I noticed the relay through the headlight motor rubber boot which is split, so maybe the issues are related. Not to self get/repair boot..
Quick Reply: Flipping headlights
