944 & 944S Forum 1982-1991
Valve guides - 944 NA 8v
Old 09-23-2016, 01:09 PM
elanman
elanman's Avatar
Default Valve guides - 944 NA 8v
Hi All
Long time since I've been on the forum , I am currently looking at replacing the guides for all 8 valves in the cylinder head . I have done numerous searches(here and elsewhere) for information on guides but all I can find is info on using the Porsche first oversize guides .
Are there any other guides available ? When the engine was relatively new were there guides available that were to the original size from Porsche ? My machine shop are proposing to grind down the oversize guides and push them in to the existing guide bores with an interference of their choice. I see from the manual the Porsche procedure is to oversize the bore of the guides and then grind to give an 80 micron interference fit
Any comments ?
Old 09-23-2016, 07:31 PM
V2Rocket
Rainman
V2Rocket's Avatar
I've used the 1st oversize on a number of heads over the years - they just drill the hole in the head out a smidge bigger...what's the problem?
Rumor has it original-size replacements are available if you ask the dealer.
Old 09-24-2016, 10:15 AM
elanman
elanman's Avatar
Machine shop don't want to do it! I see ZIMS do a std guide but they are CANNON.Anyone have experience of using them?
Old 09-26-2016, 11:42 AM
V2Rocket
Rainman
V2Rocket's Avatar
Where are you located? Perhaps another shop would be better?
Quick Reply: Valve guides - 944 NA 8v
