944 & 944S Forum 1982-1991
Cam Chain Replacement
Old 07-30-2016, 02:05 PM
RostyToasty
RostyToasty's Avatar
Default Cam Chain Replacement
Anyone know of a good guide for cam chain replacement? I found one on clarks but he uses special tools for them anyway to get around it?
Old 07-31-2016, 07:57 PM
azbanks
Freedom Enthusiast
azbanks's Avatar
I made my own special tools out of two pieces of 1/4 X 1 inch metal bar stock and two pieces of 1 inch X 1 inch wood strips. I drilled them so that they mounted to four of the cam cover bolt holes and carved small half circles in the wood to support and protect the cams. The wood sits across the cams and the metal bar stock sits on top of the wood. The holes are drilled in the same spots on the wood and the bar stock. I used the bar stock in case the wood was not strong enough by itself.
Quick Reply: Cam Chain Replacement
