944 & 944S Forum 1982-1991
Truly Hateful Porsche 944 2.5, 8v, Illuminati Owned
Old 07-24-2016, 01:47 PM
TheAllusionist
TheAllusionist's Avatar
Default Truly Hateful Porsche 944 2.5, 8v, Illuminati Owned
Has anyone seen this eBay add:
http://www.ebay.co.uk/itm/Truly-Hate...-/252470468076
I have no connection with this car, just thought the humor was worth sharing.
The Description is very funny:
Truly Hateful Porsche 944 For Sale Illuminati Owned
"This Car Got Me Sectioned"
Writing from my bed at the Psychiatric Unit, St Mary's Hospital, Southampton, on the advice of my medical consultant I am putting my despised Porsche 944 up for sale.
Why? Well, for starters it's been spreading lies about me on Facebook, saying that since my wife left me my love-life has been reduced to a bottle of 75w-90 semi-synthetic and a gerbil named Keith, which is ridiculous ... I hate semi-synths. And then there's the disobedience ... I'll explain:
I bought this car last year knowing it needed brakes, clutch adjustment and some general fettling and tidying. But it had good history, including recent belts and tensioners, good miles (137k) and was a reasonable price.
I had it trailered back and started work, getting my garage to sort the clutch and fit new discs and pads all round.
My wife was still sore at me for spending the IVF money on the car and garage bills but I was sure a morning spent in the back whilst I threw it through some bends would put her right. Alas, we never got that far.
I'm not sure if the car refusing to start from cold was a display of jealousy, but it certainly drove a wedge between me and Debbie from that day on. So much so she was completely unsupportive of my subsequent campaign to remedy this cold start issue, flatly refusing to take on any extra cleaning shifts or even to apply for the part-time jobs at McDonalds and Burger King that I circled for her in the back of the newspaper.
Fast forward two months and Debbie comes home crying. I imagine it's because her arms are hurting from the three mile walk with the groceries (she has a low pain threshold) but I ask her what's up anyway. She tells me. I do the good husband thing, pause the rugby and put the kettle on for her to make herself a cup of tea while I open one of the four-packs she's brought home. I then calmly explain why all the jewellery she inherited from her mother is in Cash Converters window: "Compression Test, Leak Down Test" I start ticking them off on my fingers, "Fuel Pressure Test; Injector Clean and Spray Pattern Test; New Fuel Pump, Fuel Regulator, Fuel Lines and Fuel Filter; Supply Damper; Timing Check and Adjust; DME and Relay Check; New Temp Sensor; Starter Motor Refurb; New Timing Belt and Tensioner, New Thermostat, Electric Fan and Air Auxiliary Valve ... These all cost money, Debbie."
But it must have been her time of the month because she became very unreasonable, calling me derogatory names and throwing things at me. Then she left. She came back the next day, but only to pack a suitcase. I haven't seen her since.
I won't bore you with many more details, suffice to say Debbie filed for divorce, clearing the house one Saturday afternoon whilst I was tinkering in the garage, leaving me just a chair and my laptop.
And so my research began: cold start issues on a Porsche 944 2.5 8v. I cross-referenced the work I'd already had done against endless forum postings, occasionally finding a snippet of something sensible, only for the post to deteriorate into irrelevant oily posturing and arguments about the pronunciation of Porsche ...
Two weeks in and I was none the wiser; in fact I was utterly confused and very nearly broke.
It was a day or two later that I first heard the voices. They were quiet at first, mere whisperings, but they told me things ... They told me that Porsche were run by a secret organisation of hybrid reptilian aliens who wanted to take over the world, and that Leonardo Da Vinci (who was one of them) had designed the first 911 back in 1518 (the year before he died) as a Popemobile. Of course I didn't believe them; I knew Leonardo had died in 1912 when the Titanic sank.
The voices told me to look at the numbers: 356 + 911 + 914 x 928 + 924 - 944 x 968 + 964 - 993 + 996 - 986 - 987 x 997 x 991 = -1.038049 ....
I was astonished, there it was, plain as day, it explained everything: Porsche were Illuminati ... confirmed.
I published my findings immediately on Facebook and Pistonheads and was sectioned by my doctor the next day.
And so I find myself here, on a narrow bed, with a drug-induced grin in the psychiatric unit of St Mary's Hospital.
And some friend the car has turned out to be, git hasn't visited me once. I bet it's found the my savings, though, and is blowing them at the Bodyshop as I write, trying to make itself pretty for the next poor fool. ****!
There it is, my sad and cautionary tale of an attempt at Porsche 944 ownership. It's cost me £3,000 in parts and labour, plus what I spent on the car originally. It starts and runs fine from warm but is a bugger from cold, and trying to work out what's wrong has driven me mad. It has to be something simple but I've run out of money and sanity to chase after it. There are some small electrical niggles that I haven't attempted yet - indicators, horn, etc - as they weren't a priority, and the windscreen is milky towards the edges. Paint is dull and has rubbed through in a few places. Small area of corrosion around aerial base. Small dent to rear o/s quarter behind arch. Cracked dash. Tyres aren't the best. This is still very much a non MOT'd restoration project.
To summarise, this is what I've had done:
Adjust Clutch
New Discs & Pads
New Fuel Pump
New Fuel Relay
New Fuel Regulator
New Fuel Lines and Fuel Filter
New Supply Damper
New Temp Sensor
New Thermostat
New Electric Fan
New Air Auxiliary Valve
Compression & Leak Down Test
Fuel Pressure Test
DME and Relay Check
New Timing Belt and Tensioners
To be honest I don't want to sell this car at all. I want to push it into a lake, or over a cliff, or open a fuel line and flick a match. Alas, it's one of the conditions I have to meet before they'll discharge me from hospital. They say my selling it will be evidence that I can 'let go responsibly.'
You've been warned.
Oh, forgot to mention that Test-Pilots, Tyre-Kickers and Time-Wasters are most welcome.
Call me (Robert) on 07803 127613 to discuss the car, or anything else you may be unsure about, ie: Gender, Favourite Colour, whether or not Darth Vader is your Father ...
Deposit of £100 required within 24hrs of Auction End or I'll offer this heap of junk to someone else and report you to the Pope.
Update: my consultant allowed me to use his computer today to read some of the emails I've been getting about the car. I wasn't too happy with his conditions (it's very sore to sit for long periods now) but he assured me it would be worth it.
I've had a few suggestions about how to remedy the cold start that I though I'd share:
1: Cold Start Injector ... I didn't know there was one!
2: Remap ECU if it's been changed.
3: Read the car a story.
4: Replace distributor cap. Is this a bit like putting the cap back on the toothpaste?
5: Put the car to bed with a blanket.
To be honest, I'm not interested in starting the malicious git ever again as it'll only get me going again.
Oh, I forgot to say, Debbie came to visit me today. She'd changed her make-up; her mascara was really neat around her eyes rather than running down her cheeks like she used to wear it. She looked quite decorative, too, almost pretty, though it might have been the drugs. Anyway, she'd come to show me something, she said.
"What," I asked?
For some reason she pulled up her jumper to show me her stomach.
"Jesus, Debbie, you want to slow down on the Doritos," I told her.
She narrowed her eyes and wiggled a finger at me. It sparkled.
"Oh, Brilliant," I enthused, "you bought back one of the rings."
She shook her head, which annoyed me as I really hate guessing games. She then went to the door and let in a man. He glowered at me as he entered.
"This is Dean," she said. "We're engaged." Dean affirmed this with a manly nod. Debbie patted her pudding stomach. "And I'm pregnant."
I got quite angry at that. Actually I got really angry at that. The doctor came in. Then two orderlies. They restrained me. They gave me an injection. I started to calm down but it still bugged me to realise that all this time she'd been deceiving me ... someone I'd trusted had been holding out on me. Standing there shameless, with a baby in her belly, it was obvious she'd had enough money for the IVF all along. Selfish bitch. It just goes to show that you never really know people at all.
Last edited by TheAllusionist; 07-24-2016 at 09:00 PM. Reason: additional information
Old 07-24-2016, 05:36 PM
snb13
snb13's Avatar
But he didn't touch the speed & reference sensors. Or AFM. Or, or...
Old 07-24-2016, 07:07 PM
TheAllusionist
Yah, your right, I guess I will pass!
Old 07-24-2016, 07:28 PM
Hunter944
Hunter944's Avatar
Default X85 944 option code
I need help with an option code on this 944. It is the X85 code. I believe it is an option package but I have been unable to find anything. Any answers?
Old 07-24-2016, 08:25 PM
thomasmryan
thomasmryan's Avatar
Debbie is pregnant!
Lol...he updated the listing. Sorry I can't help with the option codes. Starting issue is probably the air bleed o-ring rotted and the screw vibrated out.
Old 07-24-2016, 09:03 PM
TheAllusionist
I added the update to the first post and taking notes on the diagnoses offered.
Old 07-30-2016, 06:26 AM
Noahs944
Noahs944's Avatar
Very entertaining!
Old 09-08-2016, 06:38 AM
FlyBoy1986
FlyBoy1986's Avatar
If I had a bladder control problem I would be wet right now. very entertaining.
Old 09-08-2016, 05:15 PM
Shervinator
5th Gear
Shervinator's Avatar
"This listing was ended by the seller because the item was lost or broken."
Hahaha! I have never seen that before on eBay Motors.
Old 09-09-2016, 05:26 PM
TheAllusionist
I thought it was pretty darn funny and the verbiage “For Restoration or Burning at Stake” was witty as well.
Old 11-18-2016, 01:53 PM
C531XHO
C531XHO's Avatar
I owned this car before this guy. Bought it, hadn't turned a wheel in 7 years, sat outside as per pic. A previous owner must have been a player as I found a small plastic bag jammed down the back of the centre console, I thought it was drugs but when opened it contained condoms; extra safe or chocolate flavour (...didn't try them... for flavour... or fit) - explains the blanket in the back that came with the car hahaha. Anyway I went through speed & ref sensors, fuel pressure, DME relay, ECU (severely water damaged) etc etc. Put an oscilloscope on it blah blah blah, spent loads of time and some money but ran out of time, money and borrowed garage so sold it to a dealer as a non runner. It was SO solid though and I was tempted to buy it back particularly as someone had sunk £3k into it after me. Hope someone gets to love it, it deserves to live again...
Quick Reply: Truly Hateful Porsche 944 2.5, 8v, Illuminati Owned
