Replacing S2 spark plug wires
I just bought a set of Bosch spark plug wires (they are made with Beru ends) and set to replacing the Berus on my car since one had worn through its insulation. I got the main four wires replaced from the cap to the plugs, but I don't see how to remove the wire from the coil. There's a plastic cover over the assembly and I can't figure out how to remove it.
Thanks for any help!
Thanks for the response. I was able to pry it apart without trouble, but it's going to take some wrangling to remove it and get to the wire, looks like. Hopefully I don't have to remove the headlight motor.
Did you get the wire off? I think I saw your same question on a different forum, so if you didn’t get a good answer PM and I can give you better instructions how to get that cover off.
