944 & 944S Forum 1982-1991
Whining sound
Old 09-17-2014, 01:32 PM
maxsams9
6th Gear
maxsams9's Avatar
Default Whining sound
1984 944 base. I have a whining sound from the engine compartment. Thought it was the belts, tried belt dressing, didn't work. Opened power steering res. to check fluid. It was full, but while the engine was running there was no movement in the fluid. Steering seems to be ok . Should that fluid in the reservoir have some sort of movement?
I could take the belt off the pump and see if the noise is still there.
Thanks for all help.
Old 09-17-2014, 08:29 PM
plumbum
plumbum's Avatar
Could also be a tight Timing or Balance belt...or a bearing starting to make noise
Old 09-17-2014, 09:08 PM
bfle21
bfle21's Avatar
I just bought mine 6 weeks ago. It was making a high pitch whine at all times regardless of engine temp. Turns out the timing belt was way to tight. Easy fix.
Old 09-18-2014, 11:04 AM
maxsams9
6th Gear
maxsams9's Avatar
Thank you!
Quick Reply: Whining sound
