944 & 944S Forum 1982-1991
17" cup 3 twist wheels on s2. Will they fit?
Old 07-30-2014, 10:02 PM
arista
arista's Avatar
Question 17" cup 3 twist wheels on s2. Will they fit?
I am going to install 17" cup 3 twist wheels on a 1989 944 s2. Do I need spacers and if I do need spacers, what size do I need? The wheels specs are as follows.
Rear. 17 x 9. Et 47. 255/40 17 tires
Front. 17 x 7 1/2. Et 52. 205/50 17 tires
Thank you for any info.
Old 08-25-2014, 01:50 AM
doppelganger
doppelganger's Avatar
Should be a bolt on. People put 993 wheels on 944 L8 cars all the time.
Old 08-26-2014, 04:29 AM
veleno
veleno's Avatar
Once you try them on you'll know if you need spacers or not. Be sure to post some pictures, I'd like to see it.
Old 08-26-2014, 05:28 AM
Mikes3.0cabturbo
Mikes3.0cabturbo's Avatar
not quite the same wheel but from a 911, I had to use 5mm on the front to clear the hub
Quick Reply: 17" cup 3 twist wheels on s2. Will they fit?
