WTB Oil Cooler for 85.5 NA
Location: Hawkinsville / Perry, Georgia, RETIRED USAF GO BLUE
1 Post
Did you pressure check the oil cooler internal to make sure it just was not a bad seals? Porsche recommends that any time you have water in the oil you should change the ROD Bearings. If you only have oil in the water you should flush out the water system until no more oil is seen.
Cheers,
Larry
Cheers,
Larry
