DIY 928 Dash Recover
Old 02-20-2014, 11:11 PM
SeanR
SeanR's Avatar
Originally Posted by AnatolyL
OK, here goes with my usual negative bull****, but I had a baseball glove that looked just like that. I'm more curious about how you got the dash out and how you plan to get it back in...
Removing and installing are the easy part.
For someone trying to redo his dash with out sending it to an expert, this rocks.
SeanR is offline
Old 02-20-2014, 11:34 PM
Gonzotiki_666
Gonzotiki_666's Avatar
That looks pretty dang sweet man! Great write up.
Gonzotiki_666 is offline
Old 02-21-2014, 01:36 AM
Ladybug83
Ladybug83's Avatar
Wow thanks for all the kind words. I hope it helps out, god knows you've all helped me. My wallet would be much much thinner and the Ladybug would be in way worse shape without such a great international collective. just payin my dues I suppose.
Originally Posted by michael j wright
Are you going to try the pod next? I think I will give this a go on mine this spring.
Mike
Yes, I did the pod prior to this dash. I used a foam under the vinyl to hide the cracks instead of filling them. Ill put some pics below. Pretty much the same process as the dash recover except adding padding under the vinyl. I also used a heat gun to warm the vinyl in some spots that really needed stretching. The results were alright but Im not thrilled with the padding I used, the spray glue was ill-advised, the seams are suspiciously crooked, and I couldnt quite figure out the front lower part that covers the steering column. Check out the corners? Ill probably give it another go at some point and Im confident now that I could figure out a better fitment.
Also, in the pod pics, you'll see the 1st re-install with the 1st attempt of the dash recover. Notice no seams in the dash, all one piece of vinyl, but you can totally see the cracks underneath
Originally Posted by Wisconsin Joe
I highly doubt anyone is going to "Poo-poo" your work. It looks great. I can't wait to see a pic of it installed.
Your "knife spacer" tool is pretty ingenious. The binder clips were a good idea too. There are a few tricks for minimizing marks when clamping a glued fabric like that.
It looks like you used a baseball stitch for sewing the seams. IMO, that was probably the best choice. It looks a lot better than a whip stitch or overthrow would.
How long did it take? Did you keep any track of the hours you had into it?
My "to-do" list was getting shorter. Now I think I have something to keep me busy next winter.
I cant wait either! This car consumes me with excitement, I love it. What I meant by Poo Poo, was that I figured the purists wouldnt dig it and the folks that want nothing less than factory quality, which there's nothing wrong with that, but this aint it by a long shot. Id love that too but this is more realistic for me right now. Seemed like a good option based on all the complaints I read about the lower price-range recover options.
Didnt keep track of the hours, but I figured maybe a solid 2-3 weekends. A lot of time waiting for glue to dry and really taking a lot of "focus breaks". The last recover attempts I rushed through and they turned out ugly.
Originally Posted by bronto
You need to come to Sharktoberfest this year.
I will for sure, hopefully I have everything sorted out by then. Thats the plan. I was bummed to miss it last year but I had just gotten the car and tore it down as soon as I got it home.
Ladybug83 is offline
Old 02-21-2014, 03:06 AM
Danny Humphreys
Danny Humphreys's Avatar
Looks great. I plan on doing a wet layup of carbon fiber on mine. Good info on removing old material and repairing cracks. Thanks!
Danny Humphreys is offline
Old 02-21-2014, 08:53 AM
backnblack
backnblack's Avatar
Great job ! I love the baseball stitch Thank you for sharing I plan on doing this job myself very soon.
Cheers
Matt
backnblack is offline
Old 02-21-2014, 02:35 PM
antsmands
antsmands's Avatar
Exceptional work and and a BIG
THANKS for the Dwayne quality write up! It looks good in the car too!
antsmands is offline
Old 02-21-2014, 02:37 PM
z driver 88t
z driver 88t's Avatar
Wow, that is really impressive work! It show's a lot of skill and patience. I'm also curiuous how many hours you have into that project.
z driver 88t is offline
Old 02-21-2014, 04:02 PM
Ladybug83
Ladybug83's Avatar
Originally Posted by antsmands
Exceptional work and and a BIG THANKS for the Dwayne quality write up! It looks good in the car too!
Thx! I don't know Dwayne , but I like him!
A couple afterthoughts:
- change razor blades often, a dull blade will make sloppy cuts
- after applying the weldswood glue, u need to let it set up so it's tacky, but even still, u also have time to manipulate your work before it's completely dry. This is helpful when positioning the panels and when your folding the seams. It allows you time to undo the materials to work out any wrinkles and such before it's dry. And if the glue does dry before your work is perfect, just re-apply another light coat to get it tacky again.
I'm so happy you all like this write up and I'm stoked that some of you are gonna tackle this job. If you get stuck , let me know if I can help.
Thanks,
Josh
Sent from my iPhone using Rennlist
Old 02-21-2014, 04:38 PM
928Shane
928Shane's Avatar
Great job!
928Shane is offline
Old 02-21-2014, 10:09 PM
Fnic99
Fnic99's Avatar
Looks great. Eager to see how it looks back in the car.
Fnic99 is offline
Old 02-22-2014, 12:52 AM
69gaugeman
69gaugeman's Avatar
I actually think it is a neat alternative. What would be really kick *** is if you did the dash in white and had red stitches. A baseball themed interior!
69gaugeman is offline
Old 02-22-2014, 07:31 AM
M. Requin
M. Requin's Avatar
Very well done- congratulations!
M. Requin is offline
Old 02-22-2014, 10:24 AM
rgs944
rgs944's Avatar
Great job
rgs944 is offline
Old 02-22-2014, 11:12 AM
Gary Knox
Gary Knox's Avatar
VERY well done. That dash looks superb, (from a baseball fan who likes the stitching!! - HA).
Gary
Gary Knox is offline
Quick Reply: DIY 928 Dash Recover
