HVAC COMPRESSOR RELAY REPAIR PROCEDURE w/PICS
#76
Alan,
Thank you for the write up. I will be doing this soon and post the results. I have a couple of more questions.
Where do i get the female pins that goes into the CE?
Would a 53 relay work?
Are the points marked on the back of the CE panel?
Bilal
Bilal
#77
"it seems like a potential repair would be to drill a hole through the extension piece on #4 where the plastic pin was and insert and glue in a stronger (than plastic) metal pin. Not remembering exactly what it looks like, though, I'm not 100% sure that's doable."
That's it! Rebuilt many (too many to remember) that way.
#78
Alan,
Bilal
Bilal
#80
Electron Wrangler
'53 or generic Bosch style SPDT relays will both work. Genuine Bosch or Tyco.
Everything is marked on the front of the panel. send me a PM w/ email and I'll send you some more details on the relays. You can get the stock large relay terminals from Eagle Day or Vehicle Wiring Products (UK) - I got a lot from VWP(UK). I belive Roger (ROG100) also sells them individually. You can also use Ford standard terminals - though they are not such high quality.
There are some techniques that are usefiul to know for removing relay sockets & terminals.
Alan
Alan
#82
Wrapped this up today with the $9 radio shack relay. Bought it at the mall! Nice to see that at least some radio shacks still are true to their origins.
Tips: Remember REMEMBER DO NOTDO NOT crank the heat all the way up on your soldering iron. My board now requires a couple extra jumper wires because I cooked the PCB contacts right off the @$%^@! board.
Solder wick or a real vacuum solder tool is your friend. After all the electrical work I do I'm amazed I didn't have one of these 10 years ago.
I'm going to add another tricky bit to my install with an extra switch to enable/disable the compressor, but use the stock signals and switching to kick on both fans for those sit-on-rt66-at-100F moments. Or anywhere else I want to flog the crap out of the car and don't car about having the AC load on.
#85
"Wrapped this up today with the $9 radio shack relay."
Hopefully, you checked the clutch current, as the original relay was destroyed by excessive
compressor clutch current, i.e. Much more than the normal current of about 3 amps.
