PS Reservoir Hose R&R with pics
Old 01-29-2008, 01:07 AM
Dwayne
Dwayne's Avatar
Default PS Reservoir Hose R&R with pics
While I was replacing the engine oil filler gasket and had the car already up on jackstands this last weekend. I also repaired a bad leak from the two hoses coming out of the PS reservoir on the '88. The fluid return hose had a crimped connection on it so I wasn't sure if it could be repaired without having to buy a whole new hose with the extra long cooling tube that is routed in front of the radiator. Jim at 928 Intl said that bulk hydraulic rated hose would work if I could manage to remove the crimp fitting. THANKS, Jim! - That was all I needed to give it a try. So here's another procedure for curing what seems to be a common leak problem without buying an expensive return line. This post it Newbie-rated.
In order to gain access to the two fittings at the underside of the PS pump, I needed to remove the alternator. First, I disconnected the negative battery terminal just to be safe (even though I had no plans to disconnect any wiring from the alternator itself). Then remove the alternator belt as well as the PS belt. Since I was replacting the PS belt any way, both belts came all the way off.
The alternator is held in place by a 17mm long bolt on top for pivoting and an adjusting bolt underneath. The pivot bolt and adjusting bolt were loosened from taking the belt off already so I simply took them both all the way out. The alternator still hung in place after removing the bolts so rocking it back an forth and pulling down it will work it's way loose - do not lay directly underneath the alternator while doing this! The red electrical connection was long enough to let the alternator hang down and rest on a cardboard box while repairs continued. Here's a picture of the long pivot bolt (17mm).
Attachment 250510
I left the adjusting bracket in place and only removed the adjusting bolt and adjusting threads. Here's a pic of the alternator adjusting bracket still in place after removing the alternator.
Attachment 250511
Next I set about draining the PS fluid from the reservoir. I used a clean suction bulb (looks like a turkey baster) to draw out as much of the fluid as I could from topside. Then I removed the suction connection at the bottom of the PS pump (the 22mm barrell bolt) and let the remainder drain into a bucket. After the fluid was drained from the reservoir, I disconnected the two hose clamps/hoses at the bottom of the reservior and disconnected the clamp that holds the reservoir in place. Then removed the reservoir. With the reservoir out and the suction hose disconnected from the pump, I simply pulled out the molded suction hose from underneath the car. Here's a pic of the reservoir and old hose and new hose cleaned up.
Attachment 250514
Here's the PS return line showing the crimped fitting (next to the engine compartment wall). I used a dremel metal cutting wheel to carefully cut through the crimp without cutting the metal tube. With the radiator hose already out on the other job and the fan belts removed and the reservoir removed, there was plenty of room to work with the dremel. Even if the lower radiator hose was left in place, I believe there is still room to work - although someone may need to verify they have done this repair with the lower radiator hose still in place.
Attachment 250512
Here's the return fitting ready to accept the new bulk hose.
Attachment 250513
As I was looking at the original clamps used at the bottom of the reservoir, I began thinking I wanted to use something a little beefier to clamp. I needed a new beefy clamp to replace the cut crimp fitting anyway so here's what I replaced the existing clamps with. You can see for the crimp fitting on the return line, the clamping band is wider and is, of course, adjustable.
Attachment 250515
For the connections at the reservoir, I used the same beefier clamps. Here's a pic compared to the original clamps used. These clamps were the same inside diameter as the originals.
Attachment 250516
continued on next post....
Dwayne is offline
Old 01-29-2008, 01:09 AM
heinrich
928 Collector
heinrich's Avatar
Dude you make me SICK ... NO engine bay should be that clean ...
heinrich is offline
Old 01-29-2008, 01:14 AM
Randy V
Randy V's Avatar
Nice write-up, Dwayne!
Randy V is offline
Old 01-29-2008, 01:33 AM
jon928se
jon928se's Avatar
Yes - crimp can be dremelled off with radiator hose still in place. A little harder to see what you are doing - and goggles are essential as you can't "hide" your eyes safely out of the way.
jon928se is offline
Old 01-29-2008, 01:43 AM
Dwayne
Dwayne's Avatar
While I was at the imported auto parts store, I needed to pick up a new set of sealing rings for the barrell bolts connected to the pump. The manual gives sealing ring sizes as 14 X 18 for the pressure fitting (19mm barrell bolt) and 16 X 20 for the suction fitting (22mm barrell bolt). The shop also carried the same size inside diameter seals but 2mm wider so I bought a bunch of the recommended size as well as the wider size. The wider sizes are 14 X 20 for the pressure line and 16 X 22 for the suction fitting. Here's a comparison of the recommended size compared to the wider...
Attachment 250525
I also bought hydraulic rated hose to replace the return hose. It took 7.25" and I purchased 1/2" inside diameter hose which was very close to the original hose size. I attached this 7.25" length of hose to the return tube first and clamped it down with the new clamp.
Attachment 250528
Then I moved to the conenctions at the PS pump. Here's a pic of the pressure fitting at the pump. Notice the recessed groove for the sealing ring.
Attachment 250529
I test fit the new wider sealing ring and it fit very nicely in the recess. So I went with the wider sealing rings figuring it couldn't be any worse than the thinner originals. Here's what they look like when fitted on the pressure side. I torqued this 19mm bolt to the same setting as the bolts (same size) at the steering rack (22ftlbs).
Attachment 250530
Then I connected the suction fitting at the pump (also using the wider sealing rings). The WSM recommends torqueing the 22mm barrell bolt here to 43ftlbs. Used the new beefier clamp here as well.
Attachment 250531
Finally, I re-installed the reservoir (return nipple - smaller one - toward the driver and the suction nipple - larger one - toward front of the car). Then connected the return line and suction lines to the reservoir with the beefier clamps. For all connections with the beefier clamps, I ensured the wider clamp would fit between the barb and the hose stop on each connection. Sorry for the blurry pic....
Attachment 250532
At this point, everything is connected and ready to fill with ATF. Probably a good idea to fill with ATF and check for leaks before re-installing the alternator and belts. If there are no leaks, putting it back to gether is the reverse of taking it out. Alternator first (long pivot bolt first, then adjusting bolt) then re-install the PS belt and tighten and reinstall the alternator belt and tighten. Reconnect the negative terminal on the battery. Start the car and continue to look for leaks and monitor the fluid level. I filled the reservoir full before starting the engine but after running, the fluid level went down to normal level (after the new hoses and the pump were filled).
Hope this is helpful to some - feel free to comment or suggest improvements to this procedure. THANKS for reading!
Dwayne is offline
Old 01-29-2008, 02:06 AM
Dwayne
Dwayne's Avatar
The Porsche's are my babies....our other cars are jealous!
Dwayne is offline
Old 01-29-2008, 02:07 AM
Dwayne
Dwayne's Avatar
THANKS for the confirmation, Jon!
Dwayne is offline
Old 01-29-2008, 02:15 AM
Rob Edwards
Archive Gatekeeper
Rob Edwards's Avatar
Received 2,556 Likes on 1,235 Posts
There's a dremel ad out there where guy after guy is stuck in a job and the lightbulb goes off: Dremel it! I wish that light bulb had gone off in my head before I bought a whole new cooling loop and tore the front of the car off to R&R it. As usual, Dwayne, great writeup!
P.S.- Is that reservoir the original one, or is there a source for new brown reservoirs? The replacement I got was black. If that's the old reservoir, I'd like to know your cleaning secrets, 'cause that thing is supernaturally clean.....
Rob Edwards is offline
Old 01-29-2008, 10:20 AM
Dwayne
Dwayne's Avatar
Hi Rob,
THANKS for reading....it is the original reservoir - the car only has 22K miles on it but it IS 20 years old. I cleaned it with a liquid degreaser, I like to use Orange Blast - available at Wal-Mart. Rather than spray the reservoir with the cleaner and risk getting the degreaser inside, I sprayed a clean terry cloth rag with the cleaner and wiped it down. I suppose you could plug the holes on the reservoir and then douse the reservoir with the cleaner and let is sit a few minutes - that could work as well. This one wasn't that dirty.
Dwayne is offline
Old 01-29-2008, 10:27 AM
AO
Supercharged
AO's Avatar
FYI... if you find the outside of your resevoir getting oily and dirty, chances are the o-ring on the cap is dead. I think both Specialists and International carry it. And if you asked Rogaa at 928's-R-Us, he could probably get it too.
AO is offline
Old 01-29-2008, 10:59 AM
Mike Frye
Craic Head
Mike Frye's Avatar
I'd like to go on record as saying that every one of Dwayne's posts should go straight to the DIY section without delay. Another great post Dwayne!
Randy, how do I set it up so that all of Dwayne's threads are automatically bookmarked?
Mike Frye is offline
Old 01-29-2008, 11:06 AM
heinrich
928 Collector
heinrich's Avatar
FULLY AGREE
heinrich is offline
Old 01-29-2008, 11:22 AM
byrdman454
byrdman454's Avatar
Where did you buy your hydraulic hose? Does it have to be rated for a certain pressure?
byrdman454 is offline
Old 01-29-2008, 11:45 AM
LT Texan
LT Texan's Avatar
Ha Ha, yeah right!
LT Texan is offline
Quick Reply: PS Reservoir Hose R&R with pics
