928 Forum 1978-1995
Sponsored by: 928 Specialists
85-86 CO2 Test Tube Routing
Old 03-26-2017, 07:02 PM
Greggles
Greggles's Avatar
Default 85-86 CO2 Test Tube Routing
Can anyone share an image of the routing of the PS CO2 test tube for an 85 /86, along with any helpful advise to installing it. The old one was long gone and capped, but now with a replacement in hand I cant figure out how these crazy bends line up.
thanks in advance
Old 03-26-2017, 07:16 PM
Imo000
Captain Obvious
Super User
Imo000's Avatar
Look for the bolt holes at the back corner of the intake manifold (the parts that has 32V4C)
Old 03-26-2017, 08:32 PM
Greggles
Greggles's Avatar
yupp did that, which helps with the tubes exit. Still not clear how to route it around the block or header
Old 03-27-2017, 12:21 PM
Eplebnista
Eplebnista's Avatar
I will try to get you a picture tonight.
Old 03-27-2017, 11:47 PM
Dwayne
Dwayne's Avatar
Default PS Test Pipe Installation 85/86
Hello Greg,
Here's a couple of pics of the Passenger Side test pipe installed on my 85/86 School House engine. Let me know if this is what you're looking for. It is a bit of a challenge fitting it in. If I remember correctly, I believe the trick I used was to position it 180 degrees facing the opposite orientation in order to get the pipe threaded near it's final destination. Then, when close, maneuver it so it was correctly oriented 180 degrees back in order to thread into the exhaust manifold. Hope this helps - it takes a bit of patience.
Old 03-27-2017, 11:58 PM
Greggles
Greggles's Avatar
Thanks so much.
This is EXACLY what I needed!!!
Old 03-28-2017, 01:13 AM
Eplebnista
Eplebnista's Avatar
Better than mine
Old 03-28-2017, 10:47 PM
Greggles
Greggles's Avatar
Otto - also appreciate this!!!
Quick Reply: 85-86 CO2 Test Tube Routing
