Sick transmission
Sick transmission
Was having issues with the transmission and decided to investigate... a bit
Here are the K1 steel plates. It might have slipped a bit based on the hot spots.
Then, I checked the reverse friction disk.
Here's a closer look.
Finally K2 steel, which I think is salvageable. Only one hot spot.
Basic Site Sponsor
Basic Site Sponsor
What year?
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
greg brown
714 879 9072
GregBBRD@aol.com
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
Basic Site Sponsor
What people don't realize is that the internal o-rings and seals in these transmissions were rock hard 15 years ago, allowing pressure leakage and slipping. It is rare to find clutches, these days, that are not ruined from heat.
Unfortunately, the steel clutch pieces have gone up in price several hundreds of percent.....and are now very expensive.
The lining coming off of reverse is common. Mercedes changed the clutch material many years ago, to help with this problem.
There are many updates that should be done to update these '87 4 speeds to make them work better.
If you buy all the seals for the differential (you should), input shaft bearings, brake bands, and do the proper updates, there's about 2K in parts needed.
Be careful of buying "offshore" pieces. While there are SOME quality offshore pieces that do function well, they just dont last as long. In short, if it doesn't come from Mercedes, you need to think long and hard before using it.
And remember, if it doesn't work well, when you are done, I've still got a couple of these transmissions tucked away....brand new Porsche transmiscions, with limited slips.
Is it possible that the piston brake band 107 270 04 32 has many flavours? I seem to have the latest version which shows 126 277 05 38, but when I see pictures of the new part, is shows 126 277 11 38.
