FS - adaptronic 1280e
I have the top line completely customizable adaptronic ecu from Australia. I have two loops and extra pins.
1500
1500
Great price for arguably one of the best ECU's out there. This is one of the most customizable units available. Their new series does not have the flexible logic these units do. You can create any kind of 3D table you want, do custom offsets... anything you can write mathematically you an run as a "loop" between any number of inputs and outputs.
You are making me not want to sell this.
I was just just thinking I would get something when I needed it. But yeah, those logic tools are awesome.
I just felt I would get about what this does later on down the line with an aem infinity or similar.
I may be interested, but have questions. I'm faced with buying a shark tuner for a an 85 car that I put a turbo on that needs tuning. I was considering going with another system, but I would need some support from folks that have been there and done this on our cars.
Administrator - "Tyson"
If not, you have two options:
1. Mount a compatible timing ring & pickup sensor somewhere. Usually on the nose of the crank.
2. Swap to a 60-2 timing ring from an S4 automatic (I have yet to find a system which cannot use a 60-2 ring)
If this ECU can work with a 100-1 tooth timing ring, disregard......
This unit is still for sale.
By "loops" I mean "looms" and the proprietary plug.
