Sealing water bridge and thermostat housing
Hello Gentlemen,
Very soon, I will be reinstalling the water bridge and thermostat housing on the Red Witch. I understand that sealing is done with O-rings. A large black one for the water bridge to block, slightly smaller black one for the thermostat housing, and two smaller red ones for the water bridge to the cylinder heads.
However, I found black sealant on the water bridge O-rings. This dates back almost 20 years. I have cleaned all the mounting surfaces and removed all the sealant. I have new O-ring seals for everything.
Should I add supplementary sealant?
Another question: The areas where hoses connect to the water bridge and thermostat housing were never powder coated. They had some corrosion on them when I pulled the hoses off. I have scrubbed off the corrosion with a scotchbrite pad. What can I put on the areas where the hoses go to keep this corrosion at bay?
Dow 111?
Antiseize?
Other?
Note, I am not replacing the inner seal in the water bridge for the thermostat. I was replaced less than a year ago, and looks fine.
Black sealant on O-ring.
Sealant on mounting O-ring.
Corrosion on thermostat housing water outlet.
Corrosion on water outlets on water bridge.
Cleaned water outlet on thermostat housing.
Cleaned O-ring mounting area on water bridge.
Cleaned water outlets on water bridge.
Thanks for any and all advice!
Dow 111?
Antiseize?
Other?
I only used sealant on the thermostat housing that the lower radiator hose attaches to due to a PO damaging it.
Otherwise you don't need to use sealant. Just make sure all o rings and gaskets are fresh and quality.
Seth, I have some special Alodine 57 wipes that prep the magnesium/aluminum alloy for paint. (I can give you one to keep. One will do a large area.) I would clean the corrosion completely with a wire brush, apply the alodine then coat with some Rustoleum paint in the silver color of your choice. The metal needs to have some protective barrier or it will continue to do the same.
Team Owner
I would take that WB and have it bead blasted to remove all the powder coating,
this will also remove the corrosion.
Use DC111 on the black O rings and on the red gaskets.
The DC 111 will keep the O rings soft and thus they will not leak from age
NOTE if your using the the gaskets for sealing to the head,
a lite coat RTV blue or red on the connections to the head .
NOTE the powder coating may look nice, but it causes functional issues when its installed,
usually a poor ground connection,
this then causes the temp sensors to give false signals.
If you must have the PC ,
then make sure the bolt holes and the temp sensor holes and mounting surfaces are clear of any coating,
so a positive ground path can be established.
I would suggest to replace the anchor bolts for the WB. use anti seize on the threads
NOTE the rear thermostat seal looks like its failing, it should look smooth,
I would replace it,
its easy to remove now.
dont put any DC111 on the hose connections or the hose will slide off the port.
NOTE inspect the hoses for internal damage from the little nipple and the top hose from the metal ring,
these will abrade the hose and cause the leak to come from the end out the threads.
NOTE usually with original hoses its best to replace all three that go to the WB
I would replace it,
I agree with Stan but use the VR Reinzosil on the paper gaskets where the bridge meets the head.
I'll respond to everyone shortly, but first I have a question:
Should I be using the red O-rings AND paper gaskets to seal the water bridge to the heads?
I would replace its easy to remove now.
I have checked the mounting bosses for the temp sensors and the mounting faces for the water bridge to the cylinder heads. They were masked and not powder coated. I performed a continuity check of the crush washer sealing surface for each temp sensor to one of the water bridge to cylinder head mounting faces. 0.4 ohms. Which is probably mostly my leads.
The engine ran fine before I took it apart, so I believe the temp sensors were sending good signals to the computer. PO never reported any running issues of such.
I will definitely use the Dow 111 on all the O-rings. I remember your recommendations from the past. I will not put any on the hose water outlets. Thanks for that heads-up.
I am replacing ALL the coolant hoses and clamps. Starting the clock over for them. I have taken your advice and ordered another thermostat seal for the water bridge. I am a little pissed now, as that seal is only 11 months old...
I have all new bolts for the water bridge mounting. I will coat them in silver antiseize upon installation.
Thanks, Stan!
Got it. Paper gaskets have been ordered, and I will use a thin layer of Reinzosil on each side of the gaskets.
Thanks Sean and Bertrand!
Thanks for all your advice, guys!
Roger says Thanks as well. With each new piece of advice, I have to order more parts...
Note, all further work done to the engine and accessories on the Red Witch will be documented in this thread:
https://rennlist.com/forums/928-foru...l#post14536481
