928 Forum 1978-1995
Sponsored by: 928 Specialists
Mystery fastener du jour.
Old 03-21-2017, 10:48 PM
Eplebnista
Eplebnista's Avatar
Default Mystery fastener du jour.
Looks like it goes on a stud. Do not remember removing it, found under driver's side front. Recently replaced power steering pressure hose and had to remove alternator and PS pump. Also still putting things back together after pulling intake, cleaning valley, replacing throttle body shaft o-rings etc.
Car is an 86.
Old 03-21-2017, 11:13 PM
SteveG
SteveG's Avatar
Otto: I would check your suspension, and tie rods.
Old 03-21-2017, 11:20 PM
GregBBRD
Basic Site Sponsor
GregBBRD's Avatar
Received 2,452 Likes on 1,459 Posts
Keeps the muffler bearing tight.
greg brown
714 879 9072
GregBBRD@aol.com
Semi-retired, as of Feb 1, 2023.
The days of free technical advice are over.
Free consultations will no longer be available.
Will still be in the shop, isolated and exclusively working on project cars, developmental work and products, engines and transmissions.
Have fun with your 928's people!
Old 03-22-2017, 09:39 AM
Eplebnista
Eplebnista's Avatar
Should have included something in the pictures for scale. The nut portion is 10 mm, awfully small for steering and suspension.
Not the muffler bearings, I lubed them last week with the grease Greg used to sell for $160 for a tube.
Old 03-22-2017, 10:07 AM
Mrmerlin
Team Owner
Mrmerlin's Avatar
Received 2,251 Likes on 1,245 Posts
I know I have seen one of those ,
maybe from the back side of the power steering pump mount,
or the arm where its fastened to the block.
Quick Reply: Mystery fastener du jour.
