928 Forum 1978-1995
Sponsored by: 928 Specialists
1990 OEM CD-2 radio & Amp Problem
Old 04-22-2017, 05:58 PM
buccicone
buccicone's Avatar
Default 1990 OEM CD-2 radio & Amp Problem
I can't seem to figure out a dead short when I power up this radio & amp. I enter the code and it briefly displays a radio station and immediately triggers a short and blows #21 fuse. Don't know if it is the radio or Amp or both. Any guidance would help. Which buss on the CE panel are the radio wiring connected?
Old 04-22-2017, 06:57 PM
ammonman
ammonman's Avatar
I suspect it is the amp. It gets power from fuse #21. The head unit gets power from the 30 bus via the ignition switch.
Mike
Old 04-22-2017, 07:19 PM
Ducman82
Ducman82's Avatar
and we are talking stock stuff right?
Old 04-22-2017, 07:25 PM
buccicone
buccicone's Avatar
Stock Original.
Old 04-22-2017, 07:32 PM
Ducman82
Ducman82's Avatar
could be a bad wire/chafe
Old 04-22-2017, 07:38 PM
Michael T
Michael T's Avatar
I would try to power up the amp with a jumper and see if that is the issue.
Old 04-22-2017, 07:42 PM
buccicone
buccicone's Avatar
Got power to te amp. At least the wiring has 12Volts and memory voltage without the key. How can I manually trigger the amp?
Old 04-22-2017, 09:22 PM
ammonman
ammonman's Avatar
Apply 12V power to terminal #3 of the amp.
Mike
Old 04-23-2017, 09:10 AM
buccicone
buccicone's Avatar
Mike
Which is terminal 3?
Old 04-23-2017, 10:11 AM
ammonman
ammonman's Avatar
The power connection on the factory amp is on the same side as the round DIN plug connection. There should be one large brown wire (ground) one large red wire (continuous 12V power) and one small red wire (12V power on signal from the HU.) Apply 12V to the small red wire to switch the amp on.
Mike
Old 04-23-2017, 10:20 AM
buccicone
buccicone's Avatar
Mike
Will try that.
Old 04-23-2017, 10:44 AM
buccicone
buccicone's Avatar
Mike
Hooked to external power supply. Nothing seems to be happening. No buzzing, hum, sparks, quiet. Again, when I enter the radio code it blows the #21 fuse. All hooked up before the radio code is fine. Got the 12 volts at the passenger seat connector to the amp with the HU plugged in. Is the DIN plug just for audio or is it for triggering something after the radio code?
Old 04-24-2017, 08:06 AM
buccicone
buccicone's Avatar
Bump.
Old 04-24-2017, 09:13 PM
ammonman
ammonman's Avatar
When you had the amp hooked up to power on your bench did you jumper from the 12V main power connector to the 12V "amp on" input? The amp has to see constant 12V on the "power on" terminal (small red wire) to keep the amp switched on and drawing current from the main power connection. I would rig up a momentary switch between the main power in to the amp and the "amp on" terminal. A fuse inline with your power supply would be a good idea unless your power supply output is fused to the same current as fuse 21 on the CE.
Mike
Old 04-25-2017, 10:19 AM
buccicone
buccicone's Avatar
Mike
Yes, jumped the "trigger 12V" to the main 12V. Nothing happened. Already ordered aftermarket radio from Crutchfield along with 4 speakers. Original speakers shot. Just curious to find out which OEM component is bad and shorting.
Quick Reply: 1990 OEM CD-2 radio & Amp Problem
